Split wishbones/open drive+Torque Arm= NECESSITY!!!
Discussion in 'The Hokey Ass Message Board' started by Kilroy, Aug 17, 2005.
  1. kentucky
    kentucky
    Dang this is a good thread. Anyone else got anything to add? I'm contemplating rear suspension for my A coupe.
  2. buflochp
    buflochp
    from Minnesota
    I don't remember using old ford radius rods for open drive rear ends, seems like everyone made ladder bars out of whatever was laying around, some of them mothers were a hunert pounds each. I always thought the bikers were crazy enough using them to stretch springer front ends. :rolleyes:
    Good discussion, makes one think bout it.
  3. Model A Vette
    Model A Vette
    Years ago, when I was going to build a "T" coupe, I bought a '79 Monza for parts. It had a rear end setup similar to the previously mentioned '80s Camaro. It had two short lower arms which had rubber bushings at both ends. The torque arm was solidly mounted to the side of the center section of the rear, and clamped between two rubber blocks at the side of the trans. The two lower arms took care of locating the rear and transmitting engine and braking forces. The long TA took care of the rear trying to rotate under power. A pretty simple design that could easily be duplicated on a rod.
  4. Jonnyhotrod
    Jonnyhotrod
  5. Excellent old thread, man,did I post a lot?!
  6. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Here's a shot of our new kit. I know I need to get a photo of it installed.
  7. NealinCA
    NealinCA
    Another option...
    ...made from old Ford parts.
    Neal
  8. Neal, that is killer!
  9. Bigcheese327
    Bigcheese327
    Which old Ford parts, precisely?
    -Dave
  10. tdoty
    tdoty
    Looks like a modified radius rod and a front wishbone to me. Neat idea......too bad I sold my radius rods.................................
    Tim D.
  11. NealinCA
    NealinCA
  12. Anderson
    Anderson
    Thanks Neal. I was about to ask what needs to be done when you don't split the bones but convert to open drive. That helps out a lot.
  13. Bigcheese327
    Bigcheese327
    Hah, I'll be damned, so there is a good use for a Model T axle.
    -Dave
  14. NealinCA
    NealinCA
    I know what you mean. I have a 27 Chrysler tube axle for my T project...had to find some use for the old T axle.
    The end of the T axle is mated to a Model A front wishbone tube. I left about 6 inches of T axle that is spined inside the wishbone tube. I think it will be plenty strong.
    Neal
  15. Stovebolt
    Stovebolt
    Great tech.
    Is that the old 4.11 open centre we swapped?
  16. NealinCA
    NealinCA
    Thanks. Yes it is, we finally rebuilt the rearend and got it installed. Did the 3.78's work out OK for you?
    Neal
  17. OK, just to throw a twist into the conversation here: I'm planning on using 1/4 elliptical set-up on a future modified as well as using stock split radius rods outside the frame rail.
    I'm ***uming the inherent flex in the springs and shackles would still mean I need to use a torque arm. Am I correct in this ***umption or would using a TA be overkill?
  18. budd
    budd
    placing split wishbones outside your frame causes them to flex in a way they were never designed to be, when one wheel goes up over a bump they are forced to flex to allow the wheel to move, its like if your car was sitting still with both wheels on the ground and you unhooked the front of one your wishbones and flexed it up and down 6/8 inches above and below its attachment point, do that enough times and its going to fail. with or with a torque arm.
  19. Bigcheese327
    Bigcheese327
    I thought this was kind of a clever idea:
    Post-war Ford front 'bones, unsplit, being used on the rear. They probably couldn't take a lot of torque, but they might be okay for a 'banger-powered car with skinny tires.
    -Dave
  20. Stovebolt
    Stovebolt
    They will, as yet it hasn't hit our shores, ... but it will be soon though. Looking forward to geting it all together. I picked up another 4.11 recently
  21. BTTT, Great info. I have been digging thru old threads as I am building another torque arm setup for my Tudor. This Q came up in another thread this week.
  22. If dreaming all night about Neals Wishbone/torque arm setup makes me gay then let it be! Thanks for sending me those pics again Neal!
