splitting a Buick 8 manifold?
Discussion in 'The Hokey Ass Message Board' started by MistGreen50, Feb 10, 2012.
  1. MistGreen50
    MistGreen50
    from Belen,NM
    Anybody ever do this?the 4th and 5th ports share the same chamber so the only logical way to split them would be 5 and 3?Im stumped,any insight would greatly appreciated.thanks-Jaime
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Is it the 248/263 or the larger 320? The exhaust manifold on the 320s had a removable heat riser/outlet section that allowed access to the 4/5 ports; you may be able to weld a splitter plate in the center to divide it 4 and 4. I know that a lot of guys used to settle for the 5 and 3 split.
  3. MistGreen50
    MistGreen50
    from Belen,NM
    it is the small 8,do you know if the 40-41 dual ex manifold will work with the '36 single intake manifold?
  4. 302GMC
    302GMC
    from Idaho
    Do you know if the '41 dual ex manifold will work with the '36 single intake manifold?
    Yes, they'll work. A blockoff plate over the heat riser box is needed ...
  5. MistGreen50
    MistGreen50
    from Belen,NM
    ok,thanks!Now I need to find one.
