Technical Splitting Bones
Discussion in 'Traditional Hot Rods' started by Bob Bagley, Jan 11, 2025.
  1. Bob Bagley
    Bob Bagley
    IF I decide to go with auto trans on my 40 Foad and use a Speedway split bones kit will have to adjust the caster? If so, how do I do this? Thanks!
    Tow Truck Tom likes this.
  2. Dooley
    Dooley
    from Buffalo NY
    I believe that caster is set in the kit when you bolt the wishbone to the bracket
  3. Bob Bagley
    Bob Bagley
  4. Marty Strode
    Marty Strode
    Not sure what a Speedway kit looks like, but if it is similar to a CE like mine, if you need more caster, you will need to pie cut the bones at the original weld. I would install the kit, check the caster with all the weight in the vehicle at ride height, before making any changes. IMG_1247.jpg IMG_1246.jpg
    '40 Coupe Fan, jaracer, rod1 and 6 others like this.
  5. RodStRace
    RodStRace
    When a person changes the transmission, they often make other changes. Some of these including wheel & tire size and lowering can also change caster.
    Kit and car isn't the whole answer to "will it change".
    That's why @Marty Strode recommends measuring the actual car, and explains how to fix it.
    bschwoeble and Tow Truck Tom like this.
  6. krylon32
    krylon32
    from Nebraska
    Before you pull the trigger at Speedway, give 40RagTopDown on here a look. Great kit that does the same thing as the Speedy kit and is a higher quality and more reasonably priced. Support a HAMB member.
    JD69, Packrat, rod1 and 6 others like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Good idea, Send Gary a conversation and ask him what he used, his 40 convertible sits tight and he has thousands of miles on that car. HRP
  8. pprather
    pprather
  9. Bob Bagley
    Bob Bagley
    Great info, thanks again.
  10. tubman
    tubman
    Looks like a nice piece!
