Hot Rods Spot weld cutters
Discussion in 'The Hokey Ass Message Board' started by JOECOOL, Dec 16, 2015.
  1. JOECOOL
    JOECOOL
    There seems to be several types of spot weld cutters available. Whats works the best ? Are any of the Harbor Freight ones any good. Thanks
  2. The ones I like look like an end mill sort of with a little centering bit.
    never tried a harbor freight. But they should be cheap enough to give one a try.
  3. Model A Gomez
    Model A Gomez
    I've used the Eastwood one that is the mill end style and had good results. Never tried the Harbor Freight tool but have used several of their tools with mixed results. Some good, some really cheap and don't last.
  4. Phil1934
    Phil1934
    I have used Harbor Freight and this is one of the items that is good
  5. not that one guy
    not that one guy
    from So NV
    I used the H.F. Cutter a few years ago
    I only had a few spot welds to cut, it worked suprisingly well.
    loudbang and Sporty45 like this.
  6. lucas doolin
    lucas doolin
    Speaking as a devout cheapskate, get the tool with double ended cutters. BTW, this approach works much better than the "machete knife" with hammer approach. Doesn't tear or stretch the panel.
  7. Sporty45
    Sporty45
    The one I have looks just like this, but I got it at a body shop supply years ago. Probably paid way too much for it, but it works great!
  8. '51 Norm
    '51 Norm
    from colorado
    I was su****ious of the Harbor Freight cutter so I bought two, one for a spare. After drilling out a bazillion spot welds on my '51 GMC I still have the spare cutter new in the package.
  9. cshades
    cshades
    from wi
    I have the Blair spotweld cutter and the Blair hole cutter kit. They work great and reasonable priced.
  10. oldolds
    oldolds
    Be sure to center punch the spot first. Makes the job much easier.
  11. Tony
    Tony
    I've been using "roto-broach" spot weld cutters for years now.
    Bought them in a kit from Mac or Snap-On, cant remember.
    its a great kit with bit sizes from 1/4 to 5/8" that thread onto a arbor which has a spring loaded centering pin.
    They are not cheap, but i've got at least ten years of abuse on the set and they still serve me great.
    Tony
  12. indyjps
    indyjps
    I have an eastwood, I've worn out 1 side of the cutter and the cutter is jammed in there now.
    May try the HF.
    I'm thru that part of the project but need 1 to keep in the toolbox for next time.
  13. typo41
    typo41
    Work on cars everyday? Buy the good stuff
    Weekend Backyard builder like me, I bought two of the Harbor Freight and used it to remove a firewall out of a 53 Ford. The second one is still in the package. They worked for me.
  14. JOECOOL
    JOECOOL
    Thanks fellas ,I will probably only use it a couple of times a year ,Guess i'll try Harbor Freight,I am due for a new flashlight anyway.
  15. Slopok
    Slopok
    I usually get the tape measures cause I'm always losing em!
  16. 6-71
    6-71
    I used to do a lot of unibody repair,the blair cutters are good,but I have had very good luck with the HF cutters as well. also,the HF cutters will screw right onto the Blair driver.The HF cutters are on sale occasionally,and a fraction of the cost of the Blairs.
  17. '48IHC
    '48IHC
  18. gimpyshotrods
    gimpyshotrods
    Tony, are you related to Kim?
  19. 55willys
    55willys
    I use my Irwin turbo max drill bits that I got on the Matco truck. They are a relatively flat tip bit and everything over 1/4" is guaranteed against breakage or getting dull so I always have a sharp bit.
  20. Jethro
    Jethro
    X2!...what he said!
  21. Bandit Billy
    Bandit Billy
    don't forget this stuff to lubricate the cutter, like a hot knife through ****er.
