Spray Foam for sealing & reinforcement?
Discussion in 'The Hokey Ass Message Board' started by Edd, Feb 8, 2012.
  1. Edd
    Edd
    Anyone have any experience with Urethane Spray Sealant Foam? Looking to finish the floor in my coupe and need to close some panel gaps and reinforcement that run along exterior panels (ie that can't be welded).
    The idea is stabilize and keep fumes out of the car.
    Thanks
  2. designs that work
    designs that work
    Worked building aluminum boats way back, hammered rivets with plywood seats and floor boards. Expanding foam will distort aluminum and pop hammered rivets.
  3. Talk to your local auto paint supplier. There are products made for automotive use.
  4. choptvan
    choptvan
    NNNOOOOOOOOO!!!! It is a water trap at best. So unless you want to redo all you have done, leave it alone.
  5. Edd
    Edd
    10-4 on that...(welding the panels is the other way to mess them up). I understand that they make the foam with various expansion and strength rates...hoping someone could recommend one for my needs.
    Thanks..
  6. go-twichy
    go-twichy
    i sprayed it in the wall ribbes in a van i had to help stop the booming sounds coming from the sheel metal walls. it took forever to dig it out. it has more force than than you would think, and it will hold moisture. it's great for home construction, but i won't be useing it for sealing up a car or truck again! someone said it destost aluminum and pop rivets, it'll pop factory spot welds! find something better.
  7. go-twichy
    go-twichy
    "it will destort" not destost. i dont even know what that is. sorry.
  8. rcoffey
    rcoffey
    :eek:please dont!!!!!I got a 51 chevy in trade that is full of this **** . and if it aint a b*** boat ,corvette or a dune buggy stay away from fibergl***!! just my op
  9. Edd
    Edd
    OK..foam is out..let me try again:
    What do you use to seal gaps between inner and outer panels and reinforcements that run along body panels.
    I know the factory uses it in cars...maybe they don't use the term foam...but it's flexible and will fill in the gaps. Obviously seam sealer won't work.
  10. XXL__
    XXL__
  11. Rex_A_Lott
    Rex_A_Lott
    The factory (today) uses PVC, sprayed under high pressure, and oven cured.
    Not sure what they used in the old days.
  12. Edd
    Edd
    I was watching the history channel when they had a special on the Chevy Volt manufacturing process. The robots were applying the stuff all over the car to seal and reduce noise, here is a link that kinda discusses the process, you can see the firewall all "sealed" (foamed?) up.
    http://perceptron.com/index.php/en/applications/seam-sealing.html
  13. tb33anda3rd
    tb33anda3rd
    why wouldn't seam sealer work?
  14. RB35
    RB35
    Eastwood has a two part sealant in a twin tube caulking gun. It mixes the two parts in the nozzle and you need a special gun they sell. It is used by the body repair industry to glue panels to cars. It won't come undone once set up. If you have a friend at a body shop, you might be able to buy the tubes and borrow the gun.
    RB
  15. A LOT of seam sealer at least it can be removed later if nessary
  16. XXL__
    XXL__
    My (then) local NAPA loaned me the gun for free when I bought the $80+ tube-o-goo. Gun was $150 or so had I wanted to buy it. No obvious reason why it is so expensive... it's basically a proprietary-sized caulking gun.
  17. Edd
    Edd
    Normally used for gaps less than 1/8". I need something strong and flexible in my old Chevy. Pulled the wood and have it framed up with steel.
    In the areas where I can weld to the inner body points no problem..I really would like to stabilize the exterior panels that run parallel with the steel reinforcements.
  18. 56oldsDarrin
    56oldsDarrin
    there are ALOT of foams (2-part) by 3m and other companies that are intended for auto motive use and would do exactly what you want them to do.
    check with your local paint supplier (stay away from home depot stuff).
    The 2-part foams work very well, they come in a variety of expansion rates and will not attract water.
    Body shops use them all the time.
  19. Read my first post. Its called NVH foam. IT's NOT expanding foam
  20. Junkbike
    Junkbike
    from Kentucky
    [FONT=Arial, Helvetica, sans-serif]3M Fast n' Firm Seam Sealer Beige. this is a sealer
    or
    [/FONT][FONT=Arial, Helvetica, sans-serif]Dominion Sure Seal - Sure mix 5002[/FONT]. this is a panel adhesive
    the 3M stuff says up to a 1/4, but that's for there quick drying and paint-able in a certain amount of time dig
    The panel adhesive will not stay flexible
  21. 325w
    325w
    destost...........this toast
  22. tb33anda3rd
    tb33anda3rd
    3m fast and firm seam sealer is what i would use. will fill some big gaps and is pretty strong.
  23. Clik
    Clik
    Gorilla hair.
  24. garcoal
    garcoal
    squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak other than that go for it
  25. Edd
    Edd
  26. tedley
    tedley
    from canada
    That **** has no business in a build of any kind
  27. Edd
    Edd
  28. Edd
    Edd
