Technical spray gun light
Discussion in 'The Hokey Ass Message Board' started by 1946caddy, Aug 2, 2025.
  1. 1946caddy
    1946caddy
    from washington
    I haven't painted anything in a while, but it always seemed that there was never enough light inside my garage. I saw this spray gun light offered on Harbor freight and decided to try one. The problem is that they are never available locally and the nearest is always 100 miles away. I think they are a good idea but I'm wondering if overspray would tend to build up on the light. Anyone tried one of these lights?
    https://www.harborfreight.com/300-lumen-universal-air-spray-gun-light-attachment-59630.html
    Tow Truck Tom likes this.
  2. Rickybop
    Rickybop
    I was thinking about getting one. Had the same question. Figured I could stretch some cellophane wrap over it. Replace as needed.
    Yes? No?
    I like my headband flashlights though. I think the lighting from those might be better than being attached to a moving spray gun.
    flatheadpete and Tow Truck Tom like this.
  3. 1946caddy
    1946caddy
    from washington
    I think the cellophane wrap is a good idea.
  4. 1biggun
    1biggun
    You can order it and have it delivered .
  5. 1946caddy
    1946caddy
    from washington
    In the middle on the right side below the price it says "In store only"
  6. Rickybop
    Rickybop
    I guess I can't see any reason why not to have a light on both spray gun and person. Can't hardly have too much light.
  7. Rickybop
    Rickybop
    I've sprayed paint using my small flood light. Spray gun in my right hand, flood light in my left hand. Really bright. But also really hot. Finally realized I could possibly ignite paint fumes. We don't do that anymore.
    vtx1800 and clem like this.
  8. 1biggun
    1biggun
  9. saltflats
    saltflats
    from Missouri
    I think any light you can get when painting is good.
  10. Turns
    Turns
    I agree. I look at the paint laying up on the surface and need all the light I can get. I should add that most times I am not in a booth (with wall lights). I am at the age where I wear reading glasses to paint. They always get overspray on them so I use the cheap ones from a chemist for painting.
    The torch will get overspray on it for sure. I am keen to see how you go with it though
    Cheers Turns
    saltflats likes this.
  11. chlsnk
    chlsnk
    from Kansas
    I'm making a HF trip today and also some painting. If they have one I'll pick one up and report back.
  12. alanp561
    alanp561
    Just checked my local HF. They say they will have them "back in stock soon".
  13. j hansen
    j hansen
  14. 37 caddy
    37 caddy
    from PEI Canada
    I have one from a different company,i like it but it takes some getting used to.It is not the answer to all our problems but it does help.It works best for color,with clear it gets hard to see any better.I hardly ever use it anymore,it is good for checking if you have enough paint on,it helps to show up any thin spots? Harvey
  15. chlsnk
    chlsnk
    from Kansas
    No dice none in stock must be a new item.
