Spring behind rear on model "A" coupe
Discussion in 'The Hokey Ass Message Board' started by scrap metal 48, Dec 17, 2009.
  1. scrap metal 48
    scrap metal 48
    Rear crossmember is welded at frame,gusseted under crossmember and braced to frame. Spring is 1946 front. Hairpins are 32" long attached to crossmember mount.
      495.5 KB
      510.3 KB
  2. scrap metal 48
    scrap metal 48
    Stance is better too.........
  3. SniffnPaint
    SniffnPaint
    Stance looks much better.
  4. blackout
    blackout
    Has a nice profile now. That is some good home shop hot roddin
  5. Dyce
    Dyce
    Nice stance!! I wonder if the crossmember will take the twisting load though. I would do some gusseting in the corners to be safe if it was mine.
  6. LSGUN
    LSGUN
    from TX
    Looks great! What size tires are you running?
  7. von Dyck
    von Dyck
    If you completely box the rear crossmember with 3/16" plate, it'll take the twisting.
  8. scrap metal 48
    scrap metal 48
    Tires are 7.10x15" rear and 5.60x15" front............
  9. bobscogin
    bobscogin
    +1 on that. The crossmember wasn't designed for an eccentric load, so it needs some added torsional strength.
    Bob
  10. scrap metal 48
    scrap metal 48
    As stated in opening thread; Rear crossmember is welded to frame,not just rivited.Crossmember is gusseted underneath. There are 2 angled braces between crossmember and side rails. There appears to be NO cantilever effect with these modifications....But I ain't no expert........
  11. Dyce
    Dyce
    Sorry, I didn't notice the 2 braces. If you have the ends reinforced and the braces in place it should work.. Nice coupe!!
  12. orcas tow
    orcas tow
    I have been stalled on my A coupe build looking for a good clean route to install my 36 rear banjo, radius rods, rear mounted spring & closed driveline in my 31 A coupe with a rumble seat, your straight froward mod is the ticket, thanks for posting.
  13. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Why not just move the cross member back?
  14. Southfork
    Southfork
    Moving the crossmember back seems like the usual way, but this should work well too, and probably is less time consuming.
  15. fab32
    fab32
    I like your method of getting the spring centerline back for the "spring behind" application. I'm going to try that on the Model A frame I'm putting my '27 body on. Looks like it might be a little less work than lenghthening the frame.
    Frank
  16. even if you moved the crossmember back , the `46 front spring would not fit up into it
  17. Like that spring behind. Outa dump my coil overs under my roadster and do it. Maybe somday.
  18. scrap metal 48
    scrap metal 48
    Thought I would bring this thread back up to say after 2 1/2 yrs with this set up, everything was still working fine.. I have seen some questions about spring behind setups on stock model A frames and thought maybe this could help.. I've since sold the coupe and moved on to other A's..
