Technical Spring Mounts on 9" Ford
Discussion in 'Traditional Hot Rods' started by deuceroadster2, Jan 4, 2017.
  1. deuceroadster2
    deuceroadster2
    Is there a specific distance apart that the spring mounts need to be when using a 9" Ford reaer end under a Model A with the original spring with reversed main leaf?
    I have been given dimensions of 46"-46.5" and also 49".
    Is there a right answer?
    Thanks,
  2. Fordors
    Fordors
    Center to center on the Model A rear end is 49". Difference in length between original and reversed eye is a little longer so you might consider that.
  3. deuceroadster2
    deuceroadster2
    Fordors:
    Thanks for the reply!
