Spring over to spring in front
Discussion in 'The Hokey Ass Message Board' started by ironbutt, Jan 21, 2013.
  1. ironbutt
    ironbutt
    from pa.
    Has Anyone ever taken a spring over axle and moved the spring to the front ? it's a dropped speedway set up with 4 bar. Sure seems like it would work. Just wondering how to fab the perches and hangers. Any pics.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Sure,they are call suicide axles. HRP
  3. fiftyv8
    fiftyv8
    from CO & WA
    Fords from 1935 onwards were built (using radius rods not 4 bar) that way from the factory.
    I prefer the spring behind the axle for appearance purposes.
    I'd call that the true suicide front end.
    Spring in front maybe OK on a fully fendered car IMHO...
    I've seen a kit available years back but do not recall who sold them.
    I believe it used some kind of adjusting bolt locking system against the front axle to prevent the batwings moving as if they were hinges as the spring flexed, which would obviously stressed the 4 bar joints beyond what they are designed for.
  4. ironbutt
    ironbutt
    from pa.
    yeah that's what I referring to. I'm thinking if I just mimic the spring behind setup I should be fine. I can buy the batwings through speedway. Thanks
  5. oldolds
    oldolds
    What kind of car? That will move the axle back a few inches. You might not be able to turn the wheels. It will change the whole look of the car. Prob not for the best.
  6. ironbutt
    ironbutt
    from pa.
    Right, that's exactly what I want. It's a 30 five window. I put a blown sbc in it and don't want to go back into the firewall anymore. So I moved the front crossmember forward 1 1/4 " to clear the lower pulley. I'm thinking this would get my wheelbase back close to where it belongs
  7. 117harv
    117harv
    Here are a few examples.
  8. ironbutt
    ironbutt
    from pa.
    Boy I'd like to see some clearer pic of the 3rd image. Do you know where you found them ?
  9. Cliff Ramsdell
    Cliff Ramsdell
    Here's a shot of my Model A with the spring in front. This setup dropped the front and rear of the car about 4 to 5" with nothing else done.
    Rear axle is a spring behind setup.
    Cliff Ramsdell
      346 KB
  10. 40FordGuy
    40FordGuy
    I thought the "spring ahead" was referred to as "suicide" ?
    That Speedway 4-bar I'm using on my 40 pickup may be removed, in favor of a tradional split bones setup....The 4 bar, with spring ahead, puts a tension load on the upper bars, and a compression load on the lowers.......
    I'll know, after driving it a while this summer.
    4TTRUK
  11. 117harv
    117harv
    Here is the only other pic I found of it.
