Hot Rods Spring perch breakage
Discussion in 'The Hokey Ass Message Board' started by BRICE, Jul 8, 2015.
  1. BRICE
    BRICE
    from Maltby
    I have a dropped axle with transverse spring on early ford hot rod. Also has wishbone radius rods, vega steering and panhard bar. 1st spring perch broke (separated inside axle at thread termination) at 7 miles. 2nd one broke at 3,000 miles. Anyone else experience this or have an explanation? BR
  2. HOTRODPRIMER
    HOTRODPRIMER
    A photo would help,,,,I beam axle or tube? split or unsplit bones? HRP
  3. BRICE
    BRICE
    from Maltby
    I beam...split bones
  4. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    First thought is that maybe the spring is to long, are the perches adjustable or non adjustable ?
  5. F&J
    F&J
    Pics needed. One from the front to show the entire shackle system and angles, clearances... Also what type of bushings in the shackles. Poly can seize or run too tight, which can flex the perch.
    What type of perch? original Ford or some off shore repro junk that might be cast, instead of forged. Do you have a broken one to show the break surface? the pic might tell if it's cast, if it looks granular.
    Perch bolts need to be tight, and they need the cone nut at bottom to prevent problems
  6. BRICE
    BRICE
    from Maltby
    All geometry is correct and carefully engineered. Non adjustable.
  7. BRICE
    BRICE
    from Maltby
    I will work on photo. The break looks granular but Posies says they are domestic and forged. The bushings are poly.
  8. rockfish
    rockfish
    In that case you aren't having any failures then. Seriously, you need to post pic's if you want some real advice.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Photo's would definitely help,is the spring above the axle?
    Do the bones fit snug against the axle when the perch nuts are tightened. HRP
  10. A thread about broken spring perches the other day, all I can say is buy original henry forged units and get away from the aftermarket pieces.
  11. Atwater Mike
    Atwater Mike
    Agree with P&B. All the early Ford genuine perches I ever used were out of early Fords, and had considerable miles on them when I cleaned, rebushed, and installed them.
    I had never seen one break when used on street driven cars...nor I-beam axles, either: ...until the Aftermarket provided us with "Brand New" repops of underpinnings.
    Give me the gennie stuff.
  12. BRICE
    BRICE
    from Maltby
    Yes, fit is proper, perch nut also contains lower shock mount
  13. HOTRODPRIMER
    HOTRODPRIMER
  14. 2racer
    2racer
    The only thing left is your driving, stay off the curbs...
  15. LOL if you don't like the way I drive stay off the sidewalk. :D
  16. BRICE
    BRICE
    from Maltby
    Not having any luck posting jpegs?
  17. F&J
    F&J
    I would say it is impossible for a forged perch to break there in 7 miles even if something else is wrong.
    Even if the forged perch was overtightened to stress the thread termination, the threads would strip long before you could ever snap it there.
    I'd bet they are cast. Spark test with a bench grinder will tell.
    Just because a supplier was told by the manufacturer that they were forged, is not proof that they are forged.
    Also, those lower shock mounts won't always stay tight (on one side), unless they are "keyed". One side loosens as the shock puts sideways thrust on the mount, which loosens one mounts threads, and tries to tighten the other side. If you look at enough cars with those, you will see some that have loosened one side, and the shock is digging into the I beam face, because the mount has rotated. Those are poor design IMO, 1-800 bolt on stuff.
    ...and, those bolt-on mounts are now stressing BOTH ends of the perch bolt.
  18. krylon32
    krylon32
    from Nebraska
    Make sure where your buying them are selling forged steel perchs. There are some cast ductile perchs on the market. Also make sure they are really tight as any movement might lead to premature failure,
    clem likes this.
  19. Actually after reading again if they are breaking where the threads terminate I am going to fathom a guess that they have cut threads and not rolled.
  20. BRICE
    BRICE
    from Maltby
    Thanks, I agree it should be impossible to pull apart a forged bolt....I too think they are cast even if told otherwise. The lock bolts were not loose. The mounts tend to rotate but only about 3 degrees.
  21. BRICE
    BRICE
    from Maltby
    Good input, thanks. I too believe it is an issue with the part and not the construction.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Because of what some call X part & someone else calls the same thing , you really need to get a pic. posted . BTW , that was me with a broken spring pivot bolt .. Fixed mine. New tube ,newbolt
    Dave
  23. BRICE
    BRICE
    from Maltby
    Posies told me they are US made forged and they are super bell. I called P and Js and was told they are cast. My axle is forged and if had known there were forged perches available I would never have used cast. The broken ones have been replaced with SoCals, plain forged. Still working on smaller file photos. Thanks for everyone's input.
