spring perch mounts for quick change banjo with torque tube or open drive
Discussion in 'Parts For Sale' started by house of fab, Jun 27, 2017.
  1. house of fab
    house of fab
    from ashland va
    City: Ashland
    State: Wisconsin
    Price: 150.00
    Here is a spring perch that will bolt/weld on your banjo quick change rear that rotates the banjo to the rear 5 degrees.
    These brackets compensate for the rear axle assembly to rotate towards the rear, allowing the torque tube and driveshaft to align with the transmission, and can be used if your running an open drive shaft.
    150.00 which includes shipping to the lower 48
    Feel free to call with any questions.
    Havlir House of Fabrication
    Dave Havlir
    804-245-1959
    Here is a link to the straight up spring perches for standard banjo rear
    https://www.jalopyjournal.com/forum/threads/spring-over-mounts-for-your-av8-conversion.1067209/
    Spring perches are available as 2" wide for Model T spring or 2 1/4" for Model A spring
    The first pic shows the straight up version on the left and the 5 degree version on right.
    This pic shows the standard spring perch for regular banjo with torque tube.
    (notice the wheel cylinder location)
    Now the spring perch with 5 degrees of rotation to the rear.
    I wasn't born to follow...
  2. house of fab
    house of fab
    from ashland va
