Technical Spring Perch Offsets
Discussion in 'The Hokey Ass Message Board' started by Voh, Jul 22, 2026.
  1. Voh
    Voh
    IT looks like I need to move my spring perch hole to better center my rear axle. How far is reasonable before issue - can I go an inch?
    VOH
  2. anothercarguy
    anothercarguy
    Is this on rear parallel leaf springs? If so, yes, an inch is not a problem.
  3. Voh
    Voh
    yes, on the rear springs.
  4. That may depend on the head size of the locating pin bolt, sometimes as large as 7/8". Accommodating a bolt head that size would leave very little meat between holes. Smaller bolt head size bolts are available though.
  5. Deke
    Deke
    Done this many times even on rock crawling rigs that twist the leaves a LOT when articulating and never had an issue.
    Zax likes this.
  6. FrozenMerc
    FrozenMerc
    Not sure exactly what the application is, or how it is setup, but there are lots of spacer plates out there with various offset pin locations.
  7. twenty8
    twenty8
    Make sure to check the front yoke engagement on the transmission output shaft is within the proper range with the rear end moved an inch.
  8. Voh
    Voh
    Yes. This is a new build, so the length isn't set yet.
  9. krylon32
    krylon32
    from Nebraska
    When we hung the new rear end on the Ch***is Engineering rear springs under my 40 coupe we used the 2 inch adjustable lowering blocks from Speedway to center the rear end in the fender hole.
    GuyW likes this.
  10. mr.chevrolet
    mr.chevrolet
    I thought those CE kits were supposed to move the axle back about 1-1/2"
  11. 1971BB427
    1971BB427
    from Oregon
    I have moved them as much as 1.5" for the main leaf hole to center an axle. I only drill the main leaf and leave the other leafs original. If that makes the next longest leaf too close to the spring eyes I just whack it off to length.
