Projects Spring Perches
Discussion in 'The Hokey Ass Message Board' started by greasemonkey54, Nov 22, 2017.
  1. After a couple year de-rail its time to pick up where I stopped on my 37 chevy. I slapped a 57-59 Ford 9inch in to make the car roll so I could move. I need to finish the rear end install but had a question... The spring perches on my rear are wider than the factory springs. The perches measure 2.5 wide and the springs are 1.75 wide. Is the difference in width an issue or is once it is bolted down it will stay put?
    lothiandon1940 likes this.
  2. dumprat
    dumprat
    from b.c.
    It has gut not ever be a problem but it tends to break the center pin off.
    You can build a saddle for the spring to sit in so the u bolts and everything is all tight together or get new perches from a trailer axle place
  3. Mr48chev
  4. I was considering doing that
