Hot Rods spring perches
Discussion in 'The Hokey Ass Message Board' started by V4F, May 10, 2022.
  1. V4F
    V4F
    from middle ca.
    does anyone know of who makes longer (top - shackle) spring perches . i need to raise my front axle ....... thanks .. steve
  2. Mike VV
    Mike VV
    from SoCal
    I'd imagine, that "Google" is your friend !
    Just type in what you want, it'll probably bring up all kinds of places to buy from !
    Like maybe Speedway Motors ?
    Mike
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    The height of your front axle is determined by the diameter of the tires . If you want to raise the front of the frame , then you'd want to lower the perch or put a spacer between the spring & the perch .
    olscrounger likes this.
  4. 19Fordy
    19Fordy
    Steve, what is the year and make of your car?
  5. alchemy
    alchemy
    I've only ever seen the standard height perches, never one taller than Ford's. I'd bet it would never sell, as 99.99% of hot rodders want to get lower.
    How about switching out your spring? My brother wanted a high arch spring for his coupe and had one special made by Saint Louis Spring.
    oldiron 440 and irishsteve like this.
  6. V4F
    V4F
    from middle ca.
    31' ford coupe . i put a "super bell" 4" drop .......... got the recommended spring .
    perches.jpg the space between the shackel hole & the taper , i need a longer shaft (ooppss) ......... it has no travel as shackels hit axle
  7. alchemy
    alchemy
    What angle are the shackles at? Should be 45 degrees (or slightly flatter even) with all the weight on the car. If not, you need a shorter main leaf. If yes, then something is weird as they usually don't hang low enough to touch with the proper spring. You will find old axles with grooves worn in the top just inboard of the perches, but that happened when the shackle bushings wore out.
    dana barlow likes this.
  8. Hitchhiker
    Hitchhiker
    I wonder if it has a reverse eye main?
  9. 26 T Ford RPU
    26 T Ford RPU
    Steve, if you have re arched the main leaf to make it reversed that will ad an inch to each side of the spring. Get a shorter main leaf . JW
    dana barlow and Hitchhiker like this.
  10. V4F
    V4F
    from middle ca.
    yes it is a reverse eye .
  11. V4F
    V4F
    from middle ca.
    goin to do some serious rechecking today . thanks all for the help
  12. alchemy
    alchemy
    One clear picture could help us help you.
    kadillackid and X38 like this.
  13. V4F
    V4F
    from middle ca.
    good idea , as i explain poorly . get them in morning .............................. thanks
  14. Hitchhiker
    Hitchhiker
    Yep. That's why its rubbing the axle
    26 T Ford RPU likes this.
  15. V4F
    V4F
    from middle ca.
    did not arch .......... straight from speedway
    pix today .................... thanks as i know this is wierd
  16. manyolcars
    manyolcars
    I reversed the main leaf on my avatar using the press. It went back on the car with no problem and I did not shorten it
  17. fiftyv8
    fiftyv8
    from CO & WA
    Picture first up probably would have short circuited all the questions required.
    I look forward to your pictures.
    X38 likes this.
  18. 26 T Ford RPU
    26 T Ford RPU
    Steve, where the photos!! JW
