Hot Rods Spring perches
Discussion in 'The Hokey Ass Message Board' started by 29 coupe, Dec 22, 2023.
  1. 29 coupe
    29 coupe
    I need to put front shocks on my 32 pickup would like some info on the ones that bolt on the bottom of the spring perch bolts some have a key way but who has the right spring perch bolt
  2. alchemy
    alchemy
    First you’ll need to get your terminology correct. A spindle bolt is another name for a kingpin, and has nothing to do with the spring or shocks.
    Some aftermarket vendors sell perches with an extra long threaded portion to let you attach those lower shock mounts. And, some even sell a set with the keyways to keep the shock from rotating. I think it’s a great idea. Ask your supplier if they have that kind. Also ask if they are forged or cast, as obviously forged is better.
    X38 likes this.
  3. 29 coupe
    29 coupe
    Thanks
  4. Mr48chev
    You would have to check but I'm thinking that these are designed to work together. Screenshot (582).png Screenshot (583).png
