Technical Spring spreaders
Discussion in 'The Hokey Ass Message Board' started by atch, Sep 9, 2022.
  1. atch
    atch
    Here are pix of spring spreaders that I've collected over the years. I'm posting this to:
    1. help @chessterd5 with his "Lipstick on a pig" project, &
    2. to have spring spreader ideas available to all hambers.
    Please add your pix to this thread if you have any.
    So; here are the pix (if any of these are your photos please step up and take credit):
    clem, warbird1, winduptoy and 13 others like this.
  2. Mr48chev
    Wow a lot of info there, You had me somehow thinkinking those things that get stuck in coil springs that like to pop out.
    I've got to mark this for later and study it a bit.
    Tow Truck Tom and lothiandon1940 like this.
  3. chessterd5
    chessterd5
    from u.s.a.
    Thanks for the help it is appreciated!
    winduptoy and lothiandon1940 like this.
  4. lumpy 63
    lumpy 63
    I think you covered the subject very well. Most people think the spring simply bolts on..:p
    flatheadpete and lothiandon1940 like this.
  5. Kiwi 4d
    Kiwi 4d
    That’s a huge variety for sure. Some great ones and some I wouldn’t trust my life with. Even with a correct early ford spreader there is a whole lot of pressure when you get near putting the shackles in. Be careful out there.
  6. This works with the Quick Change on a Model A rear spring in my car, with stock or reversed eyes.
    F9DB1072-F4CD-433F-9944-EBA3062E31D7.jpeg 126D82D8-0DB5-4A4B-B772-4E8D3792BA35.jpeg A03A5BC3-D002-4585-A3CD-B07F1E7A5D85_1_105_c.jpeg D9CEE11B-7DF9-41E2-969F-8678EBD11817.jpeg
  7. Flat Roy
    Flat Roy
    I remember many years ago (50 or so) to remove the rear end from myA bone ( 2 door sedan) I put two pieces of 2 X 4 between the spring and the axle. Then stacked bags of sand on the back seat untill the spring was spread enough to take tension off of the shackles. Removed the shackles. took sand bags out. Jacked car up . removed spring. :D Don't need no stinking spring spreader :p
    AHotRod, TagMan and set me on fire like this.
  8. clem
    clem
    ^^^^^^ and I thought I was the only person that did that type of thing……
    (Although I used the weight of the engine, not bags of sand).
  9. Kiwi 4d
    Kiwi 4d
    Taking this unusual lowering attempt out, zero travel with spring riding on the axel tube. Original later spring spreader roughly modified for a model A. I found the only way to properly reference the square head of the through bolt into the ch***is of a model A with the body on was to cut a hole in the floor. The floor is almost touching the crossmember. CD70CDC4-99E2-49A0-9D99-DB017BC5502A.jpeg DB8321F7-2BB9-4342-A7CD-75629F0A269A.jpeg
    winduptoy and deadbeat like this.
  10. chessterd5
    chessterd5
    from u.s.a.
    Ouch! That spring has seen better days.
    deadbeat likes this.
  11. 48stude
    48stude
    This one is mine that I made to install a painted reverse eye spring. Bill
    my2nd40, rod1, deathrowdave and 7 others like this.
  12. Dave G in Gansevoort
    from Upstate NY
    42969-blazing-saddles-1974.jpg ****o install springs, easy...
    swade41, alanp561, deadbeat and 3 others like this.
  13. chessterd5
    chessterd5
    from u.s.a.
    ****o only a pawn in the game of life.
    It only matters where the choo-choo goes.
    alanp561, winduptoy, deadbeat and 2 others like this.
  14. RICH B
    RICH B
    Almost 60 years working on old Fords and have never used a spring spreader; I have always use a long threaded rod and good C clamps to take apart or ***emble springs.
    Front springs a wood block under the eye and clamp over the axle and center bolt to spread enough to get the shackle in.
    Now in the car on an A or T spring over axle may be a different matter; but that need has escaped me.
    rusty valley likes this.
  15. rusty valley
    rusty valley
    Me too. On a spring over like a model A, I install only the main leaf first. To do that, I hook up one side, and put a 2x4 between the axe and spring eye on each end, which holds the shackle up near level, and sit on the spring to get the other end hooked up.
  16. Going to add a few photos here.
    I made my simple spreader for stock non reversed springs from 1" square tube and 1/2" or so threaded rod.
    The main point of the story is to use TWO nuts, one acts as an index point
    for measuring progress and the other the jam nut that advances the spring.
    Measure the "spread" distance of your shackles eyes on the axle then get the spring spread as close as you can on the bench with a tape measure before moving to the install.
    BE VERY CAREFUL, I've seen a spring DESTROY the spreader and luckily not anyone whom was close...
    teach'm likes this.
  17. mixerman
    mixerman
    Here's a set up I used to spread the leaf spring, but all so set the ride height.
    This only works with the spring mounted in the frame.
    The bottom bolt that is at the bottom of the spring is protected with a 1-1/4" wood dowel
  18. krylon32
    krylon32
    from Nebraska
    I have used the spring spreader that my great uncle made when he owned the Ford dealership in Alexandria NE. for the last 50+ years. He went broke in the mid 30's but the spreader lives on. Simple design made from 1 1/4 ready bolt inserted into a thick wall tube with the end of the tube and ready bolt smashed flat, heavy flat washer welded on the tube and a big square nut for adjustment. Simple but efficient.
    warbird1 likes this.
  19. atch
    atch
    lothiandon1940 likes this.
  20. Fortunateson
    Fortunateson
    An old guy told me to use a Porta Power...good advice?
  21. atch
    atch
    On the front that will work.
    On the rear you still have to get around the banjo somehow.
  22. Fortunateson
    Fortunateson
    Good point re: the rear...
  23. Fortunateson
    Fortunateson
    Good point about the rear.
  24. I really like the first photo for "A" spring nice and safe.
  25. atch
    atch
    I stand corrected. This is a 1948 Ford with spring behind rear and they used a Porta Power:
    Someone correct me if I'm wrong, but I believe that a spring-over-axle would require something like the ones previously posted.
  26. deathrowdave
    deathrowdave
    from NKy
    Damn now you have me thinking . I reversed the eye on my 32 rear spring . I know I borrowed a spreader from an old timer and used it to put the spring in . It was heavy wall round tube and large threaded rod , ground to fit into the eyes . I look tomorrow . Really got me scratching my head now . Front was a piece of 2x4 on the axle , and a floor jack .
