Technical Spring time
Discussion in 'The Hokey Ass Message Board' started by goldmountain, May 13, 2024.
  1. goldmountain
    goldmountain
    Looking over my little '34 Austin Ruby, its quarter elliptic rear springs won't work well with my narrow rear axle so I think that twin semi-elliptics would be easier. The frame kickup in the rear sticks up sort of like a T bucket. Every stock rear spring setup I have ever seen has the springs somewhere near level. Can anyone see ant reason why mounting the rear shackle end higher would pose a problem?
  2. swade41
    swade41
    from Buffalo,NY
    Longer the shackle the sloppier the cornering will be and it'll wear out the spring eye bushings faster.
  3. goldmountain
    goldmountain
    Not going with long shackles, just concerned with strange angle on the spring. Also, pinion angle isn't a problem either.
  4. Unkl Ian
    Unkl Ian
    Is there a pic ?
  5. BamaMav
    BamaMav
    from Berry, AL
    Why not just use a set of coilovers?
  6. goldmountain
    goldmountain
    I'm cheap. It's a small car and I have these springs left over from a small trailer project that didn't get built.
