Spun aluminum tank
Discussion in 'The Hokey Ass Message Board' started by iceokie, Mar 27, 2011.
  1. iceokie
    iceokie
    My fuel cell has a bunch of old stickers, glue from a previous attachment point and overall grunge all over it. I've tried acetone and lacquer thinner on the glue bands and it wont touch it. I know it will come off with a wire brush but think it will mess up the spun finish, any ideas on how to clean it? I'm building a hot rod not a show car but I still want it to look presentable. The pictures don't show how grungy it really is. Thanks
  2. davo461
    davo461
    Sometimes, dabbing on Eucalyptus Oil will dissolve sticky stuff. Just a possibility!
    How about a heat-gun and mild scourer? Maybe even a calico polishing mop on a hand drill?
    Just trying to help. Hope you get it sorted; I like to imagine what the tank may be getting fitted to!
  3. MikeRose
    MikeRose
    from Yuma, AZ
    I've used carb cleaner to get adhesive residue off of a lot of things. Might work?
  4. Ruiner
    Ruiner
    Red scotch brite pad and some acetone...just keep working the scotch brite in the same direction as the spun aluminum finish...worst case scenario it gives you a duller brushed aluminum finish when you're done...
  5. <FANG>
    <FANG>
    from W.L.A.
    Lighter fluid
    works for me
  6. 1971BB427
    1971BB427
    from Oregon
    Might not be glue, but hot glue! I'd take a propane torch and warm it up, then wipe it with a rag to see if it comes off when heated. If it does, then just keep gradually warming it, and wiping it off as you go. After that a little brake cleaner on a rag to clean the residue.
  7. Straight Axle Steve
    Straight Axle Steve
    Marson Air Craft Stripper. (comes in a blue can with an airplane on it) Works everytime. Will not hurt aluminum at all.
  8. swade41
    swade41
    from Buffalo,NY
    Have you tried goo-gone ? That stuff does work.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've had the same problem at times using the same solvents you have tried. Paint Thinner has done the trick instead.
  10. iceokie
    iceokie
    thanks guys, I like the scotch bright idea. it needs something abrasive with a solvent but I hadn't thought about scotch brite.
  11. Oldmanolds
    Oldmanolds
    3m makes some stuff called citrus cleaner. I've had it do things that solvents won't
  12. WD40 is good on releasing glue.
    Brake Cleaner has also worked for me too.
  13. Bandit Ls-1
    Bandit Ls-1
    use Laquer thinner with the red scotch pad till the glue is off, then hit it with a grey scotch pad which is less abrasive and will smooth out the red pad scratches.
  14. GaryB
    GaryB
    from Reno,nv
  15. Master of None
    Master of None
    Try 3m General purpose adhesive remover.It takes the residue of 3m tape used to attach body moldings off. Works well for stickers for me anyways.
  16. srdart67
    srdart67
    from Sharon, Wi
    do not use a propane torch it will make it look worse. if you need heat use an electric heat gun!
  17. hotroddon
    hotroddon
    Not to mention do you really want to heat a gas tank witha flame?
    Try Goof Off, works great
