Technical Squaring a block vs decking a block
Discussion in 'The Hokey Ass Message Board' started by Budget36, Aug 24, 2024.
  1. RodStRace
    RodStRace
    Yeah, and a CNC is only as good as the operator and the shop. Tools wear, tolerances stack and the jigs and clamps need to be monitored for clean surfaces and proper clamping.
    Budget36 and Desoto291Hemi like this.
  2. lumpy 63
    lumpy 63
    We are rapidly loosing machine shops here.
  3. gimpyshotrods
    gimpyshotrods
    I have seen SBC's that were what I would consider way off.
    Many had somewhere between 200k to 300k miles on them, and did not have issues but extreme uniform wear.
    You'd be surprised how few specs are exact from back in the day.
  4. lumpy 63
    lumpy 63
    I had a 1965 283 that was .015 out of square on one sideo_O
  5. Budget36
    Budget36
    I was going to check 4 corners yesterday, but got busy with something else. Should be able to the end of the week.
    big duece and lumpy 63 like this.
  6. gimpyshotrods
    gimpyshotrods
    Not all that uncommon.
    Truckdoctor Andy likes this.
  7. Kerrynzl
    Kerrynzl
    Mike bore it first ,Then dummy ***emble the 4 corner pistons and rods [with no rings] and measure the corners at TDC
    I did this on my 283 and then I swapped out the 4 pistons with the remaining 4 and measured again [just in case there was a rod length/compression height tolerance]
    My block was decked so the pistons were .005" out of the hole. And we used standard .039" Fel-pro 1043 gaskets leaving .034" quench.
    You can go a lot higher out of the hole with careful measuring and parts selection
    ekimneirbo, lumpy 63 and Budget36 like this.
  8. Pav8427
    Pav8427
    Make sure that if you are boring before decking to have it bored with a bar that registers of the crank bores. If your shop has one that registers off of deck, you would have to deck first, then possibly re deck to get piston tops where you want.
    Budget36 likes this.
  9. Budget36
    Budget36
    I’m trying to keep the static CR at 9.4-9.5. I’m checking finances:). Been a very expensive past month or so, and my daily is giving me some issues. So need to hold some in reserve.
    I need to call the shop when I have time this week get a rough estimate on boring it, honing it and square decking it and balancing the rotating ***embly.
    I feel I have the crank in pretty good shape, chucked it up in my lathe and polished the journals with 600 or 800 emery cloth with WD as my line:), mains with .001 undersized bearings were looking good at pretty close to .002. I never checked the rod journals though.
    The thrust bearing was a bit tight, but fit it to .003, I may go a bit more, I know it’s the low end of the spec, so will MMO and 600 grit them down another .001 to be safe.
    But it all hinges on what the shop cost they tell me is. It may be a little now, a little later, etc.
    Life is fun when that ******* “unexpected Bill” knocks on your door!
    seb fontana likes this.
  10. distributorguy
    distributorguy
    from MN
    Its not just "Not uncommon" - its EXPECTED! I don't recall ever having a SBC block on the Blockmaster where both decks were at the same height, unless someone had previously made that correction. 15 thou off is normal, unfortunately. Its also common to find a 5-7 thou dip in the block surface.
  11. Joe H
    Joe H
    Be careful when measuring off piston tops to get deck hight, the piston can and will rock in the bore. I measured off the center or along the wrist pin line of the piston. You can also wedge the piston to one side, just be sure to do the same thing for each piston for repeatable measurements.
  12. George
    George
    On the now imploded WebRodder site they did a build on a 331 Hemi. When checked the decks wern't square front to back or top to bottom, also the 2 decks wern't equal distance from the center line of the crank.
  13. ClayMart
    ClayMart
    With the old factory machining processes, would it be likely that the cam bore centerline would not necessarily be parallel to the centerline of the main bearing bores? Maybe both these boring operations were done with the block in the same fixture to eliminate that problem.
    Budget36 and ekimneirbo like this.
  14. Joe H
    Joe H
    1963 Olds,
    1962 Ford,
    It took some pretty big machines to make blocks! Wonder how may the inspector looked at before he could spot defects just by eye balling them?
    ClayMart and Budget36 like this.
  15. metlmunchr
    metlmunchr
    I have bored several inline 71 series detroit diesels for oversize sleeves. Doing these in a horizontal boring mill, what I found was moving from one hole to the next using the factory bore spacing, the original spacing doesn't necessarily match the factory spec. I first thought this might be due to the block being stress relieved over time via heating-cooling cycles during operation, but realized that's likely not the case as the spacing variation was random.
    Its possible to determine where the nearest bore center should be based on measurements from the machined surfaces of the main saddle that carries the thrust bearings, and from that center as zero you can sweep each bore with an indicator and have a map of the actual vs theoretical center for each bore. Takes maybe 45 minutes to do the measurements and know where you are before you start cutting. The worst hole center determines how much oversize you need to bore to end up with all the centers where they should be and all the holes the same size since you wouldn't want to have to use different size sleeves for different holes. You actually could do that, but most people would consider that sloppy work.
    Anyway, in doing that work, it made me wonder how accurate the bore spacing is on the run of the mill car engine, and if that is something that's normally checked when doing machine work on a block destined for performance use.
  16. theHIGHLANDER
    theHIGHLANDER
    Before I had machining done on a BBC I was told all of em are "high" on opposite corners after a time due to stresses in operation and production stds. I might be backward cuz it was a while ago (30+yrs) but I think it was high in the p*** rear and drivers front. .018 off, and we wanted it down a bit so we took off .024, and yes squared to the crank center line.
  17. squirrel
    and that seems to me to be something that won't affect performance at all....
    gimpyshotrods and Budget36 like this.
  18. RodStRace
    RodStRace
    This is an interesting tidbit. The beloved flathead V8 ford camshaft is off center. I'd never owned or worked on one when I saw the blueprint for it.
    https://www.jalopyjournal.com/forum/threads/flathead-ford-asymmetrical-why.457580/
    Budget36 and lumpy 63 like this.
  19. seb fontana
    seb fontana
    from ct
    And the cylinders are not on the cl of crank either, by .168. Some engine manufacturers are doing the offset as it changes the piston dwell. Think Ford new that?
  20. Tickety Boo
    Tickety Boo
    from Wisconsin
    Cloned Hot Rod magazines Junk Yard Jewel vortec head project about 26 years ago with a few more improvements, a**** them we also bored and 0-decked a 4-bolt main 350 block for the build.
    This was the first block the local machinist 0-decked as he had just bought the grinder capable to deck a block, so I was his first customer, he made a short set of head location dowel pins and installed them too the same height as T.D.C. of a piston and rod installed in all 4 corners, he then set up grind to equal the height of the pins.
    Used .041 Fel-Pro head gaskets with forged flat top pistons and it's still running strong. :)
    Budget36 and big duece like this.
