Got a squeal when letting the clutch out on brisk takeoff. Maybe the pilot bushing but not sure. Running while stopped, clutch in, out or in between, in or out of gear - no squeal Moving with clutch in or out- no squeal Easy starts - no squeal Hard starts, squeal begins with letting out the clutch, goes away when clutch fully out. Almost a groan, like when you first get out of bed in the morning. Thinking it's the pilot bushing while the input shaft catches up with the crank, but again it's quiet when stopped, in gear with clutch in. Any other testing I can do?
Thanks. Hate to take it apart and not find it, or worse put it back together and find out it's something in the trans. So I was just searching and came upon this. Describes my problem but I don't understand the explanation. Anyone? Step 2: Listen for sounds as you release the clutch pedal. In some cases, the throw out bearing will make noises as you release the clutch. This is commonly caused by the center bearing grinding on the flywheel as it's moving towards the transmission. from: https://www.autoblog.com/2016/12/12/how-to-troubleshoot-a-car-with-clutch-noise/
that above statement makes no sense. if your throwout bearing is touching the flywheel, you have bigger problems. I would suggest getting a new pilot bushing and a throwout bearing. I tend to replace both if im in there just for good measure. Also What trans motor combo is it? are you using an adapter or original bell housing? When the trans is out, check the input shaft bearing in the trans. Ive seen those get loose and make all kinds of sounds yet still drive just fine while it slowly grinds the trans apart....
What kind of friction material are you running on the disc? I've heard more than a few med. duty trucks with metallic disc's make the kind of noise you're describing. After awhile they get glazed from the heat and make a groaning/ squealing sound.
Had the exact same symptoms as you on a sm420, was the br*** pilot bushing wallowed out, everything else was good.
Hey thanks guys. Ford with a T5, stock stuff. I had ***umed pilot bushing but it's quiet stopped in gear with clutch in (crank is spinning, input shaft not) but I guess it could only do it under load. Or the clutch disc, that's a thought. Only happens on hard takeoffs, I try to avoid it, as noted I hope it's not the input bearing wearing out the trans. Hope to keep driving it until it needs clutch work. Yeah that explanation from the link I posted makes no sense to me either.
Can you remove your floor transmission cover and remove the transmission inspection plate? That will allow you to hear where squeal is coming from as you depress clutch.
