Squeek in my exhaust? WTF??
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Nov 5, 2010.
  1. Damn that's a loud squeek. I don't start my new motors unless they have mufflers, so I can hear what's going on. That said, I'd muffle that thing before going any further (NO MORE STARTS!), and it should be a lot easier to diagnose. BUT, if you can hear that over that loud exhaust, I'd be concerned
  2. oldcarfan
    oldcarfan
    from missouri
    heard that noise from an old 327 i had in a 36 chevy, it was a spun bearing.
  3. Harms Way
    Harms Way
    Well lets see,... It's a small block Chevy,... also called a "Mouse" engine,...I would ***ume that the Mouse is trying to escape out of the exhaust.
    A Rat (big block Chevy) sounds totally different,.. and are usually found in "rat rods" :eek::cool::D:D:D
    :)o I would like to apologize in advance for the aforementioned post,... I just couldn't help it,....... :p)
  4. plan9
    plan9
    that is loud.... have you even checked the oil yet? i mean, drain it and check it... not just dip stick.
    groucho is right, better stop starting it up..
  5. Antny
    Antny
    from Noo Yawk
    Dumb question: have you tried running it with the fan belts removed? Just thinking it could be the belt itself, water pump, alternator, etc.
  6. Atwater Mike
    Atwater Mike
    Marty...
    Pull the plugs, do a standard compression check.
    1. The 'squeak' is at low R.P.M., (idle) so if it is a leak at the exhaust valve, you will find it.
    2. As you have already isolated it to #5, it should be a matter of comparison with the rest. Good Hunting....
  7. gasshole
    gasshole
    from new jersey
    I had a 396 that sounded just like that it galled a rocker ball. If you have roller tip rockers that could be it.
    Scott
