1952-59 Ford SS Gas Tank
Discussion in 'Off Topic Hot Rods & Customs' started by Nalakaya, Jan 10, 2021.
  1. Nalakaya
    Nalakaya
    Has anyone ever dealt with either Rock Valley or Rick’s Tanks to have a SS gas tank made?
    I want to add an in the tank fuel pump on my 56 and thought the best way maybe just to have a tank made.
    Thanks!
    Jeremy
  2. fordsbyjay
    fordsbyjay
    from Lafayette
    I have a Ricks Tank in my 64 Falcon. They are very expensive but real nice. They can make changes if needed as well. Aeromotive and I think HOLLEY make universal drop in units for a stock tank.
  3. evintho
    evintho
  4. okiedokie
    okiedokie
    from Ok
    I have the Drake tank and with the in tank pump fittings in my 55.
  5. Nalakaya
    Nalakaya
    Do you think the Bob Drake 55 tank is the same as a stock 56 tank? It would be nice if it would bolt right in.
  6. evintho
    evintho
    Not sure. It seems my tank is from a '55, not a '56 like I said. My bad! I pulled pics from C&G Ford's site and the '55 is the only one offered with in tank pump bracket. The two tanks do look a bit different. Different part #s too.
    '55.....
    '56......
    With that said, the filler necks are on the same side. Call and get dimensions for both. The '55 tanks are a bit different than '54's and all I had to do was lengthen the straps a bit and shorten the filler neck 1" to make it fit.
  7. Nalakaya
    Nalakaya
    I’ll give them a call.
    Thanks for the help!
