Hot Rods St 400 Auto trans
Discussion in 'The Hokey Ass Message Board' started by iafraser39, Aug 3, 2023.
Tags:
  1. iafraser39
    iafraser39
    from Warmland
    My st400 auto trans is pushing fluid out the dip stick tube.
    Not a grat deal, but enough to leave a bit on the floor when parked.
    This is a new phenenomon as I have been driving this for 4 years
    since rebuilt. It has a B&M kit in it. I have checked the fluid level
    and also made sure the breather tube is not plugged. Any help
    would be greatly appreciated
  2. 1-SHOT
    1-SHOT
    from Denton
    Check the breather tube real close Mud Daubers like to build nest on them, and run a piece of wire thru it to be sure it’s not clogged. You may have to change the grommet on the filler tube.
    Hamtown Al, SS327 and Kevin Ardinger like this.
  3. squirrel
    Can you tell for sure which end of the tube? top or bottom?
  4. SS327
    SS327
    I’ve only seen a plugged vent cause this. Damned mud daubers!
  5. As @squirrel stated, blowing out the top or leaking at the bottom? If out the top, vent is plugged. If out the bottom, does it have the single O-ring seal, or the newer cup style seal? How are you cooling it?
  6. iafraser39
    iafraser39
    from Warmland
    Thanks for the reply.
    I blew on the vent tube and because of fluid level, the fluid game out the top of the filler tube.
    I forgot about the torque converter letting fluid bleed back into the trans.
    I also wrapped a strip of towel at the top of the filler tube, went for a drive, the towel had
    fluid on it. ever where else is sealed good and do other traces of fluid.
  7. squirrel
    And you're sure it's not overfull?
    jaracer likes this.
  8. jaracer
    jaracer
    If it is coming out of the top of the filler tube, I would suspect either it is over full or it is overheating.
  9. Atwater Mike
    Atwater Mike
    Where'd ya get the dipstick? On a similar note, is the fill tube shortened?
    Nobody likes a lyin' dipstick...
  10. OK, since you have been driving it for 4 years and this is new, what changed? Add any fluid? As I asked earlier, how is it being cooled? Through the radiator? Typically, when the fluid cooler fails internally in the radiator, you see transmission fluid in the coolant. Does the fluid look burnt? Shifting still firm? If a clutch pack is slipping, heat will build up and expand the fluid, but usually out the vent.
  11. BJR
    BJR
    To get fluid to come out of the top of the filler tube the vent would have to be plugged, as it's lower than the top of the fill tube. It should come out of the vent first. Also to push fluid out the top of the fill tube, the vent would have to be plugged or the case would not build up pressure.
    SS327 likes this.
  12. iafraser39
    iafraser39
    from Warmland
    10 years ago when I built the car I shortened the fill tube
    and the dip stick by the same amount. It has been OK for all this
    time.
  13. iafraser39
    iafraser39
    from Warmland
    Nothing has changed, I have an external cooler ( Deral) mounted under the frame rails.
    My temperature gauge on the ****** runs at 150 deF.
    The shift is solid. The vent is clear. O built the car some 10 years ago and everything has been
    OK up intill now.
  14. justpassinthru
    justpassinthru
    What type of filter does the trans have?
    Is it an early 400 with the side winder filter or the later style flat type that lays in the bottom of the pan?
    Reason I ask is the later type with a Dacron element has a tendency to become restricted over time.
    If that happens, there is a possibility that the fluid returning to the pan can't be picked up fast enough and the fluid level will rise to the rotating parts and fluid will be pushed up the fuller tube, just like if it were overfilled.
    Bill
  15. iafraser39
    iafraser39
    from Warmland
    Thans for the reply.
    The ****** is a 66 switch pitch. It has deep pan (Extrafluid) and
    a flat filter ( br*** screen type) mounted at the bottom of the aluminum
    pan.
  16. Is the torque converter shifting from low to high stall as it should? IIRC there is a plug in one of the pump ports (looks like the end of a fuse) with an orifice drilled into it of about .100". If that orifice plugs, the converter may not be filling properly resulting in a high fluid level.
  17. Kevin Ardinger
    Kevin Ardinger
    The tube the filter is attached to, did you double up the o rings where it fits into the case? I always put two o rings there to prevent aeration.
