Stabbed in the Leg!
Discussion in 'The Hokey Ass Message Board' started by Detonator, May 24, 2004.
  1. I'm running an early toploader in my r-p/u. Found an NOS Hurst shift linkage kit, which mounts nice and solid, but it puts the shifter right up under my leg. Now I could heat and bend a new shift lever to center it -- or fab up a spacer to move it over (about 3 inches) -- but I'm wondering if there are other ways to handle this...?
  2. junk runner jr
    junk runner jr
    Shift with your foot [​IMG]
  3. it's usually in my mouth.... [​IMG]
  4. DrJ
    DrJ
    #1 Sit closer to the door.
    #2 Widen the cab.
    #3 Bend the lever over to the right at the base and just let it come up at an angle instead of putting an "S" in it and makin it too short... you'll get used to it [​IMG]
    #4 You already answered your own question I think...Just do what it needs to function.
  5. AHotRod
    AHotRod
    Just modify or make the handle to go where you want it.
  6. Paul
    Paul
    Editor
    [ QUOTE ]
    [/ QUOTE ]
    hmm... modify something to fit..
    isn't that what it's ALL about? [​IMG]
    Paul
  7. well, duh... [​IMG] thought I might come across something imaginative
  8. #2 1/2===switch to right-hand steer [​IMG]
  9. now THAT'S what I meant [​IMG]
  10. Paul
    Paul
    Editor
    slide the seat over to the middle and hold the stick between your legs.
    did I say that?
    you know, like a single seat modified!
    Paul
  11. Don't use that shifter. [​IMG]
    Actually I'm not sure I follow you here. IF its a early Toploader, why is the shifter now on the side and to the left.
    Or are you talking about using a 40and up side shift box?
    then I would still say use the early topload/topshift box and life will be good [​IMG]
  12. 55olds88
    55olds88
    Go RHD, life is much more fun if you are driving on the wrong side of the car [​IMG]
  13. Hey Rudy -- it's a toploader out of an early Mustang-Falcon. Has the same narrow bolt pattern as a 50's era three speed. The shifter linkage mounts on the forward part of the tail shaft, but to the left side. It would be pretty straightforward to fab up a spacer -- or just bend an L in the shift arm -- to move it over and out from under my leg. But I thought someone might have come up with a more interesting solution (like right hand drive). [​IMG]
  14. yorgatron
    yorgatron
  15. Ok I got ya.
    Well then here is my highly technical solution.
    Bend the shift arm [​IMG]
  16. I'm not certain, but might the Jeep shifter which comes outta the top work. I think there was a post on this awhile back. Creeper
