Technical Stainless leaf springs?
Discussion in 'The Hokey Ass Message Board' started by farmer013, Dec 11, 2024.
  1. farmer013
    farmer013
    Has anyone got any experience making stainless steel leaf springs? I've come across some info on it being done, but no real details. Any info would be appreciated. Does it work? What grade stainless?
    Sharpone likes this.
  2. deathrowdave
    deathrowdave
    from NKy
    Wow , is it worth the end result ? Any task can completed , but the cost I’m sure will out weight the benefit
  3. 34Phil
    34Phil
    2"x3/16"x3' 304 from McMaster is $84. They don't show longer or thicker.
  4. distributorguy
    distributorguy
    from MN
    316L is a little more resilient than 304 and resists rust better. It can also handle the heating process better if you need to make spring eyes. Its been done for show cars, but not sure about drivers? I suspect it would be fine if you can handle the price tag.
  5. noboD
    noboD
    The L signifies Lead to make it easier to machine. Why not just nickel plate regular springs?
    6sally6 and Sharpone like this.
  6. Unkl Ian
    Unkl Ian
    I used to work at a spring co, doing hand made prototypes.
    We used a variety of materials, depending on the application.
    Stainless was one. Don't remember the exact specs, but some
    was "full hard" and others "half hard".
    jet996 and Sharpone like this.
  7. Unkl Ian
    Unkl Ian
  8. 38Chevy454
    38Chevy454
    Old HAMB metallurgist here. There is nothing to prevent using stainless steel for a leaf spring, or coil spring for that matter. Just make sure you use the right alloy, as most springs are heat treated. That means a heat treatable grade of SS, such as 400 series or precipitation hardening type (you may have seen 17-4PH spindles as an example of PH SS). The more corrosion resistant 300 series can only be made stronger by work hardening, and would not be a normal choice. The bigger problem of SS leaf spring is just cost and special processing.
    Unkl Ian, pirate and Just Gary like this.
  9. farmer013
    farmer013
    I know it seems kind of crazy with the cost, but I work at a stainless steel fab shop and a 20' lenth of 1/4 stainless FB is about $200 and I can polish them to mirror finish which would be a lot cheaper than chroming now adays. Just gotta figure the right grade, I've seen a few things saying 304 is good but then others saying no. Just gonna take a little more research I guess
