Stainless welding to sheetmetal
Discussion in 'The Hokey Ass Message Board' started by Flop, Jan 6, 2010.
  1. Flop
    Flop
    this is on a project i have for a customer.. i cant think of any other way to attach the stainless to the steel besides spot welds. screws/ nuts will be seen. the perforated polished stainless is gonna go inside of the visor over the taillights giving it a more finished look since the taillight area was changed.. any suggestions?
    the stainless wont cover the taillights just mimick the inside of the little visor to clear that up.
  2. bobjob55
    bobjob55
    can you silver solder the stainless ???
  3. Flop
    Flop
    i have no idea ,stainless is a new animal to me... i have a tig so that will do everything i just dont kno if those 2 metals will go together nicely
  4. langy
    langy
    Yes you can weld stainless to steel.
  5. Flop
    Flop
    dig it thanks man!! now next question should i use stainless rod ? will there be any crazy corrision later?
  6. K13
    K13
    If you weld it you might want to spray the regualr steel with a Weld through primer (UPOL copper is about the best) to keep the corrosion to a minumum under there.
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    309 rod will work the best for the two dis-simular metals
    do it every day here at my facility
    we like "blue max"
    keep yer gl***es on after you weld it..when the weld cools the slag will pop off..really ****s if your standing there looking at your weld and dont have safety gl***es on:eek:;):cool:
  8. Flop
    Flop
    yeah the weld thru was for certain k13 ,****s expensive!!!!
    will the 309 rod filler metal rust or is that a stainless rod, von rigg?
  9. K13
    K13
    309 is stainless
  10. Flop
    Flop
    dig it thanks guys!!!!!
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    its stainless
    look up
    "blue max" rod..its nice shtuff
    let me know if you have a tuff time getting it..
  12. krylon32
    krylon32
    from Nebraska
    Been welding steel and ss with ss 308 rod for the last 20 years, haven't had a problem yet.
  13. art.resi
    art.resi
    Lots of tricks you can do with a tig.
  14. This is no big deal....both are steel thus both will weld together, MIG or TIG
    Also, you can weld chromoly with steel.....the whole deal here is "What's the purpose", "Why am I using the process I'm using?" etc......
    Just because you can, doesn't mean you should etc....
    Really depends what & why & what kind of outcome you want.
    Joining stainless with mild steel just lets your fillet weld rust later down the road while ss looks nice.....so should you do it, can you do it......??
    If you run out of wire on a mild steel weldment, yes you can use ss wire etc......but is it cost efficient......it's all them types of questions a cert'd welder will respect.
    Carl Hagan.
  15. Louie S.
    Louie S.
    Von rigg fink is right buy some 309 and weld it, we do it all the time.
  16. Flop
    Flop
    thanks guys trip to the welding store for some 309 rod tomorrow ...do they sell rod in small quan***ies or do you have to buy that huge box?
  17. mikeyfrombc
    mikeyfrombc
    depends on the store , they may want you to buy a box which is typically 10lbs , get a small rod 0.045" or 1/16" , i,ve played with 308 and DOM and it welds very nice , you may get lucky and be able to buy it by the rod or in a 1lb bundle i was able to get Silicone Bronze in a 1lb lot from 1 source where another only sold it in 10lb boxs
  18. sloorider
    sloorider
    could you weld studs on the back of the stainless plate, then secure it through holes drilled in the metal with nuts or am I in left field?
  19. Homemade44
    Homemade44
    As posted you can weld it. If it is only a trim piece you could use one of the new panel adhesives to attach it. The panel could be put on after painting the main body.
  20. cal1954
    cal1954
    from Omaha, NE
    Any stainless rod will be fine. If you have some SS tie wire laying around you could use that for fill rod.
  21. Steelsmith
    Steelsmith
    Just so you know, 'standard' steel is a iron/carbon based product, and is cl***ed as a 'low alloy' steel. The carbon content is usually made up in hundredths of one percent. Other elements can be added to the mix to make chromoly or tool steel or any of the many differing tensil strength's designated for various structural requirements.
    Stainless steel is cl***ed as a 'high alloy' steel. It generally has 10% chromium and may contain other elements which make up the different alloys of stainless steel. Some are as high as 30% chromium! Most all forms of stainless steel contain at a minumum 50% iron.
    In general you need to match the filler rod to the stainless steel to be welded, (same number). There are some exceptions to this 'rule'. To make sure you use the right filler, consult a welding supply house or one of the large manufacturers of welding equipment. Don't take someone's verbal recommendation. They have nothing to loose. However if you have a weld failure and someone gets hurt, it's your ***!
    Just food for thought ...
    Dan Stevens
    dba, Steelsmith
  22. Flop
    Flop
    thanks for the input steelsmith...no critical welds here (purely decorative ) gonna be about 10 spot welds 16/th of an inch holes in the perforated stainless to the visor deal.
