Hot Rods s'talk PCV valves for SPECIFIC engines
Discussion in 'The Hokey Ass Message Board' started by 6sally6, Jul 1, 2025.
  1. 6sally6
    6sally6
    I have a "SBF engine" and am curious to know IF a PCV valve for a Hi-Po 289 would work better on my engine than....just what's on sale at Poop Boyz or where-everrr...
    Seems I read somewhere that Hi-Po engines with 'snotty-idle...more CR...less vacuum etc'. require a different valve..
    All you 'Shivel-lay Fellas' with bumped-up power levels/Vettes...do y'all use Hi-Po PCV valves ? OR.....is it all just a sales gimmick to sell high(er) dollar parts ?!!
    Thx for sharing from this vast well of knowledge....
    6sally6
  2. Rich796
    Rich796
    A pvc valve is like a $10-20 part regardless of the application. For example Purolator # PV774 for SBC lower vacuum applications.
  3. squirrel
    I used to buy the valve for the higher performance applications. But it's been a while.
    I did peek in the most recent Standard catalog I have, which is 30 or so years old. They only have listings back to 1970 for Ford PCV valves. so I can't get you the part number you want, sorry.
  4. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    This is the solution:
    https://mewagner.com/
    Expensive, but worth it. I fought for YEARS trying to find a PCV that worked correctly with the snotty cam in the SBC in my 55. This thing has performed flawlessly since I installed it a couple of years ago. No more oil leaks, no more oil vapor stink in the car., no more idle/transition issues.
  5. kabinenroller
    kabinenroller
    I use and recommend the Wagner PCV valve.
