Hot Rods Stall converter
Discussion in 'The Hokey Ass Message Board' started by 63' MERC, Jun 22, 2014.
  1. 63' MERC
    63' MERC
    I just had my stall converter adjusted to 3200 & installed it last night. Its clicking when I turn the motor over manually by the crank to put torque converter nuts on ? I think its the converter ticking or trans front pump ? Help !
  2. saltflats
    saltflats
    from Missouri
    Did the studs rattle in the flex plate holes when you bolted up the ******?
  3. hipster
    hipster
    Might/better triple check she is seated all the way in, been known to fool folks.
    Dropped a 3K in mine thurs, almost got tricked myself.
  4. tfeverfred
    tfeverfred
    Did you make sure to seat the convertor properly? Listen for that, "click, thunk".
