Technical Stalling when warm
Discussion in 'Traditional Hot Rods' started by 8x0x5, Jul 30, 2017.
  1. 8x0x5
    8x0x5
    Having what seems to be a vacuum issue in my 55' ford.. Will not hold idle after it's warmed up and then won't restart... it will cruise perfectly once you get rolling but will die the second you let off throttle and take it out of gear..
    I had it idling perfect and running great for about 60 miles yesterday. Parked, then came back out an hour later and ran great for another 20 miles and then once I got off the highway, she died and wouldn't start back up again.. any thoughts?
  2. Shop boy
    Shop boy
    Does it always start back up once it cools down?
    Did this problem just surface?
    What distributor are you using?
    A little more info might help us to help you.
  3. GordonC
    GordonC
    You already have a post with this question in it. Did you try or follow any of the suggestions you got in that one?
  4. d2_willys
    d2_willys
    from Kansas
    put a vacuum gauge on it and monitor the vacuum. It might just be something else.
  5. 8x0x5
    8x0x5
    I posted it twice by accident. Phone won't let me delete.
