stamped pontiac valve covers?
Discussion in 'The Hokey Ass Message Board' started by rustisgold, May 4, 2010.
  1. rustisgold
    rustisgold
    does anyone know if pontiac ever made any valve covers with the "pontiac" lettering stamped into them? im looking for something similar to cadillac valve covers of the 50s exept by pontiac to grant the lettering onto the stock valve covers on my 1975 400 pontiac-a dirrect bolt on is not required
    buddyamigo likes this.
  2. Bob K
    Bob K
    from Antigo Wi.
    They made them for Canadian Poncho's in 57 or so
    B:)B
  3. wvenfield
    wvenfield
    Yep. there is a long thread on here somewhere if you want to search for it. Pictures and all.
  4. koolkemp
    koolkemp
    Flatheadfever has some on his 52 Pontiac he has posted some pics in the thread mentioned above.
  5. bryan6902
    bryan6902
    These are the covers that came on my 57.
    I believe they started with these in 57, since most of the 55s and 56s I have seen in the yards have the silver Strato Streak applique on them. How long they made them, not sure?? It was in the thread mentioned earlier, maybe some one could post a link.
  6. jonzcustomshop
    jonzcustomshop
    the canadian ponchos had sbc valve covers with a different script than the one pictured above, angled block letters, my 56 has them.
  7. US 55-56 Pontiacs had an aluminum plate on one side with the lettering stamped in rather than the cover itself stamped, would be an easy add-on to later valve covers, as opposed to cutting and welding.
  8. 55chieftain
    55chieftain
    57 is the only year with the stamped scripted valve covers...The ends are more rounded off than the later valve covers but they will work on the newer heads. The bolt pattern is the same.
    Either buy spacers or double up on the gaskets so the rockers don't hit the valve cover. FYI RA IV vc gaskets are 1/4" thick as opposed to the regular vc gaskets which are 1/8".
  9. LowFat48
    LowFat48
    find some Pontiac script emblems and mount those on your covers....
  10. rustisgold
    rustisgold
    sweet! thanks for the info guys, i want to use them on a steel t bucket im starting that will be a visual tribute to the lightning bug, so stamped is a must. ill do a better search and see what i can find
  11. JP L
    JP L
    Did you ever find a set of valve covers? I'm now fabricating custom valve covers in Red Deer AB. I started doing this out of necessity while trying to find a set of the Pontiac script covers. You can see the set I fabricated in the background of this photo of a set GMC ones I made.
    Cheers,
    JP
    Bad Oman Cl***ics
    403-872-7101
  12. Fordors
    Fordors
    Rocker arm oiler? Or?
    Sharpone likes this.
  13. pprather
    pprather
