Technical Stanchion mount
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Aug 25, 2025.
  1. Timothy Murphy
    Timothy Murphy
    Im building a 1932 Ford roadster with a gl*** body. The body came with no steel infrastructure so I am adding 1” sq tubing throughout the body. I know I need some steel across the bottom of the dash to support the steering column but do I add steel where the windshield stanchions will be mounted? The gl*** body is pretty robust in this area. Do I just add a steel plate or large washers to the stanchions bolts? Thank you.
  2. NJ Don
    NJ Don
    Tim,
    My gl*** body was built by "Rod Action" in Canada, they sold their molds to Speedway ... I think? There are plates gl***ed onto the body, inside, where the stanchion bolts go through. They are about 2" square and slightly bent to follow the curve of the cowl at that location. That was for the stock '32 windshield, I am now using a DuVall style on my roadster. (avatar). The plates look to be 1/8" thick.
  3. Timothy Murphy
    Timothy Murphy
    Thank you. I’ll check the area with a magnet, I know aluminum won’t be detected
