Technical Standard Shift on Cadillac 365 and 390
Discussion in 'Traditional Customs' started by Chop50, Aug 13, 2023.
  1. Chop50
    Chop50
    Hi All,
    Anyone done this conversion or am I relegated to going automatic?
    Thanks, Steve
    warbird1 likes this.
  2. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Well I once had a 33 Ford with a 365 Cad adapted to the closed drivetrain. There are adapters, but you might have to do some looking for a flywheel for it. Flywheels can also be adapted if needed.
  3. PackardV8
    PackardV8
    Yes, aluminum adapters and flywheels existed back in the day.
    No, they're not easily found today and they're not cheap.
    Maybe, depends upon your friends and contacts. It's just time and money.
    Also, are you flexible about your*******? Cad-to-whatever are specific and if you find one, are you willing to live with that******* and make it fit your frame and driveline?
    The best one to find would be a Cad-to-Studebaker or others which used the Borg-Warner bolt pattern. Then, you could use a T85 or T10. Just be aware the B-W transmissions used application-specific input shafts. The depth of a Stude adapter will be different than a Ford adapter.
    jack vines
    warbird1 and vtx1800 like this.
  4. 73RR
    73RR
    Just curious...are there any common bolts or dowels from the early Cad to the BOP?
    Could be a starting point....
  5. Chop50
    Chop50
    Ideal I guess would be T5 or Tremik TKX
  6. jaracer
    jaracer
    I seem to remember a customer, when I worked in a filling station, who had a 62 or 63 Cadillac with a 3 speed on the column. It was supposed to be a special order. I know the sales data books back in the 60's had all kinds of off the wall options.
  7. flamedabone
    flamedabone
    irishsteve and guthriesmith like this.
  8. Hollywood-East
    Hollywood-East
  9. seabeecmc
    seabeecmc
