Stanley Tool Identity
Discussion in 'The Hokey Ass Message Board' started by hddennis, Oct 29, 2009.
  1. hddennis
    hddennis
    from Georgia
    I've tried in vain to identify this Stanley tools age, use and value. So far it's split between woodworking, plastering and auto body lead work. My guess is lead work. Can anyone here give me definitive answers so I can move this to a new owner or relegate it to a dark corner of my tool box.
    Thanks, Howard Dennis
  2. 61TBird
    61TBird
    Send it to me and I'll figure it out! :D:D
    Are there ANY numbers stamped on it??
  3. TomWar
    TomWar
    Looks like "Vixen" File for lead. No Idea of worth, but my deceased Brother in law was an old bodyman, and some of the old tools are worth quite a bit.
  4. The37Kid
    The37Kid
    Dean! Welcome to the HAMB! You'll like things here, sure there are lots of Hot Rods but a lot of other interesting things as well. I think that may be a lead working file, but it may be a plaster crown moulding tool as well. Lots of old houses with big crown mouldings were moulded on site plaster creations.
  5. hddennis
    hddennis
    from Georgia
    Thanks Bob and Y'All , I 've had good help here in the past and probably should have tried here first. The only thing stamped on it are:
    Stanley
    SW
    Made In USA
  6. Welcome to the HAMB Dennis!
    If you go to the sister site "garage journal" you might get some answers- lots of tool guys on there.
    Hey, where are you in GA?
  7. hddennis
    hddennis
    from Georgia
    Thanks Mac, I'm surprised at your "handle" down here. Tell me if you've ever heard this " Y'all Ain't from around here , are ya?" I'm originally from NY but live in Byron, Georgia now.
  8. grits
    grits
    Barrel rasp.?
  9. Haven't had too many troubles with it, but every once in a while I still get a, "Well bless your heart"...:D
  10. dirty old man
    dirty old man
    Welcome to GA!
    That ain't a vixen blade file, that I do know, cause I've used them back in the 60s on the job @ the old Fisher Body plant in ATL.
    Vixen file has curved teeth with the end of the teeth trailing to the rear so as to allow the lead filings to exit the teeth and not load up the teeth.
    The lead joints were normally done in a booth with an extraction type ventilation system and the workers in an air supplied hood. They used disc grinders.
    Any repair work done involving lead after the booth work was done using files and hand sanding blocks so as to not ****ter lead dust all over the place. Don't see hardly any lead joints in cars today.
    So I don't know what that tool is, but it ain't a vixen blade file for finishing lead joints.
    Dave
  11. hddennis
    hddennis
    from Georgia
    Just wanted to thank everyone for their help in finding out what I found. Here's what a tool forum dug up:
    "This is a No. 694 Half Circle File Holder for a "Vixen" file for auto body work. You will find it in the 1939 Catalog #139. Tool not included in Walter's book. Do not know value, sometimes this type of holder brings good money, mostly of limited interest from my observations."
    Courtesy of Peter Evans at Sawmill Creek Woodworkers forum
    Howard Dennis
  12. dirty old man
    dirty old man
    OK, I can accept it being the holder for a vixen blade file. That would explain the straight across grooves in the base, allowing more flexibility to bend.
    Dave
  13. hddennis
    hddennis
    from Georgia
    Maybe my picture is too small, the teeth or grooves are curved.
    Howard Dennis
  14. willymakeit
    willymakeit
    Could be used for both. Curves on barrels, wooden wheels or metal work depending on cutting surface. Cant tell by picture, but there should be some sort of adjustment device.
  15. pimpin paint
    pimpin paint
    from so cal
    Hey,
    The tool you've pictured is in fact, a file holder for a lead shaping file!
    I purchased one at a swap last year for $15.00. I can't recall running across a panel shaped like it, other than reverse crowns in early Corvette doors, but I'm sure they are out there!
    S****y Devils C.C.
    '' It's time for another Tea Party!"
