Star Wars hotrods...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Oct 12, 2006.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    Go to www.landspeed.com/magneticasb.asp
    The North American Eagle land speed car(jet) is using magnetic brakes. How the hell do these work?
    I got the story from GG Gazette September 2006 issue page 14.
    Can someone 'splain this to poor okie?
  2. bob hindman
    bob hindman
    you get a boat anckourrie then you magnatizee it then uoy toas it out 400 mph on theee sallt///// woo stop
    hiney
  3. SUHRsc
    SUHRsc
    i have no idea but i want to venture a guess
    #1...using magnets as the actuating mechinism and using a normal type brake for the physical stopping power
    or #2 ...using opposing magnets on opposite sides of the rotor and another rotor type thing fixed to the car with electro magnets...so it tries to attract the magnets each time they p*** by each other?
    sounds like a good idea if they can do it without a physical connection and therefore not have any heat buildup
    Zach
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    note to self...keep Bob away from the computer till after he's sober...
  5. Mr. Mac
    Mr. Mac
    Are you guys bored?
  6. DeuceDog
    DeuceDog
    from Breese, IL
    Larry...no plile-up?
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    what was your 1st clue?...:p
  8. synthsis
    synthsis
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    I think you're on to something in choice #2 Zach, cause I remember in the article it said that the heat generated was only 300 degrees. There couldn't be any contact at that low of temp.
  10. caffeine
    caffeine
    from Central NJ
    similiar to the magnet train technology.
  11. DrJ
    DrJ
    Probably works like an electric motor with the armature wired so you can run it backwards.
    If so, it will probably work as a "reverse" gear too.
  12. 3wLarry
    3wLarry
    from Owasso, Ok
  13. squirrel
    then where does the engergy go?
    normal brakes work by turning kinetic engergy (m*** times velocity) into thermal engergy (heat)
  14. ynottayblock
    ynottayblock
    they are filming a do***entary on the team building the car. i saw the first part up here on the discovery channel, which covered the build and some initial testing. I havent seen anything on them making a run at the record yet. It is a neat group of american and canadian engineers, kinda doing it on their own. It is very "gr***roots" compared to the british team that currently holds the record. the part i saw had some details on the braking system, but im no engineer so what they explained sounded like greek to me.
  15. loogy
    loogy
  16. DrJ
    DrJ
    That's how and why electric/magnetic motors get hot.
    Doin' the Electron Dance.. :D
  17. synthsis
    synthsis
    on mag brakes, it should be used in a regenerative system like they use in hybrids, capture the spent energy and use it again when it's needed.
  18. Big Tony
    Big Tony
    I'm not sure BUT i think i will be safe a stay with what works cause i've had accidents and they hurt dammit.
    New idea for the HAMB... a comedy show between 3WLarry and Bob bickering. ya'll kill me :~)
  19. Zumo
    Zumo
    Electromagnetic Like on security doors.
  20. ratstar
    ratstar
    Give me a set. I'll try em out on the A-bone
  21. 3wLarry
    3wLarry
    from Owasso, Ok
  22. Bugman
    Bugman
    Exact same way that all regenerative hybrids work. the kenetic energy is converterd to heat and electrical energy/ Ultrasimplified : they act as generators. the more electrical load you put on a generator, the harder it is to turn, and the more energy is absorbs.
  23. mufflerbearing
    mufflerbearing
    from owasso,ok
    Larry its just like the brakes on my trailer,electro magnets work with electricity,the more juice you give them the better the magnet holds,thus a magnet next to the brake rotor with enough juice will stop just about anything
  24. Comet
    Comet
    One of the guys, I think the owner, works at Boeing and they did a nice write up in the employee on line newspaper on him and his quest a few months back.
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    Thanks Mark. I didn't know this technology was already mainstream...I live under a rock at times...:rolleyes:
  26. loogy
    loogy
    According to Lev X, the brake manufacturer, these are not electromagnetic.
  27. Ruiner
    Ruiner
    could you imagine an electromagnetic clutch...that'd be a neck-snapping hard launch...stuff like this has always intrigued me, and chances are it comes from VERY old designs from the 40's and 50's that have long since been forgotten in the file cabinets at the patent office...
  28. VonMoldy
    VonMoldy
    from UTARRGH!
    Star Wars came out in the 70'S right?
    Magnetic Brakes are old school.
