start without a flywheel
Discussion in 'The Hokey Ass Message Board' started by 270dodge, Nov 13, 2012.
  1. 270dodge
    270dodge
    from Ohio
    Did you ever start an engine without a flywheel? In 1965 I saw a guy (in a junkyard) start a Max Wedge Mopar laying on it's side and reved it up to show me that it was a good one. He advised me to never start one without the flywheel or the torque converter on it. The price of the motor was $150. and I turned it down!
  2. I thought the starter ring gear was on the flywheel.How did he start it?
  3. In 1965 I saw a guy (in a junkyard) start a Max Wedge Mopar laying on it's side and reved it up to show me that it was a good one. He advised me to never start one without the flywheel or the torque converter on it. The price of the motor was $150.
    Just how did he crank it without a flywheel? :confused: HRP
  4. Willy301
    Willy301
    Starting it without a flywheel is not a good practice, and not an easy feat...unless you are good at pull starting a V-8...Also the result in an engine that requires the flywheel for balance could be very harmful. The torque converter does not have to be on the engine though. The harmonic balancer is required though.
  5. propwash
    propwash
    from Las Vegas
    the OP is asking can it be done. The wrecking yard guy started it conventionally, and then issued the warning. I couldn't even begin to imagine how one would start any kind of a larger car engine without the ring gear in place. Wrecking yard guy was basically just dreaming crap up. Next nugget of wisdom was likely going to be a caution about starting an engine when the cylinder heads are off.
  6. yes, if you mean without using the flywheel. 1911 lozier, bunch of model tees, model A, 1907 cadillac and a few others i have used the hand crank.
  7. 270dodge
    270dodge
    from Ohio
    Did not say that he started it without but I think that some engines have a flexplate that could accomidate a starter drive.
  8. GregCon
    GregCon
    from Houston
    Well.... there is a difference between a flywheel and a flex plate. So you could start an engine with only the flexplate (not a Mopar though) and have no flywheel or TC.
    The bigger issue to me is why an idiot would start an engine that is lying on its side...I'll bet the oil system loved that.
  9. 296 V8
    296 V8
    from Nor~Cal
  10. 270dodge
    270dodge
    from Ohio
    Read the OP without dreaming up a wierd answer before.
  11. 270dodge
    270dodge
    from Ohio
    The question is have any one of you actually seen an engine running without a flywleel? Not some goofy girly shit about a starter rope or some such shit.
  12. how are you starting it? magic?
  13. GregCon
    GregCon
    from Houston
    Yes. I have seen them started with no flywheel. They were cranked with a ring gear attached to a flexplate. I have also seen smaller engine, such as a flathead 4 Ford, running with nothing attached to the crankshaft. It was started with a hand crank.
  14. 270dodge
    270dodge
    from Ohio
    Read the post.
  15. Canus
    Canus
    Flywheel/flexplate: same fricking thing!!
  16. dirty old man
    dirty old man
    Super modified and sprint cars (oval track) run no flywheels. They ae pushed off in gear before a race. To stop you must either shut off engine or take out of gear. Once out of gear while running, it must be shut off again before putting in gear to push off once more.
  17. 270dodge
    270dodge
    from Ohio
    There ya go a real answer.
  18. 270dodge
    270dodge
    from Ohio
    No a flywheel is heavy and a flexplate is lite.
  19. 296 V8
    296 V8
    from Nor~Cal
    The starter rope is directed at the guy that said that to you…. Not you relax FNG
  20. EnragedHawk
    EnragedHawk
    from Waco, TX
    So far he's gotten 7 posts out of this thread. Give him a few more minutes and he'll be an Old School HAMBer. :D
  21. are you looking for a list of engines that are balanced by the flywheel? or what is the point of the question?
  22. 270dodge
    270dodge
    from Ohio
    Well I might have misread that. I just want an answer from someone who has seen it and I think that I have it.
  23. Engine man
    Engine man
    from Wisconsin
    So an aluminum flywheel is not a flywheel?
    Some diesel engines with a pony engine starter were belt driven off a pulley on the front.
  24. 270dodge
    270dodge
    from Ohio
    What are you doing now?
  25. 270dodge
    270dodge
    from Ohio
    Yes an aluminum flywheel is a flywheel- Read the OP.
  26. saltflats
    saltflats
    from Missouri
    Ihad a 65 Falcon that some put a 351 in and problems with mounting a starter so thay put a generator/starter on it and used it to start it. Dont think it would hurt an engine to start it without a flywheel even if it was external balanced as long as it was not rapped out to red line.
  27. 270dodge
    270dodge
    from Ohio
    But when you started it did it have a flywheel or converter on it?
  28. Ester Eddie
    Ester Eddie
    from Alaska
  29. cometman98006
    cometman98006
    I didn't start it that way but years ago just before the traps my clutch blew taking out the flywheel and jaming the scater shield into the throttle. I was doing over 100 mph in my channelled '34 B altered 5 window Ford with a full Olds engine. I hit the kill switch as it passed 6000 RPM or it would have come apart.
  30. 270dodge
    270dodge
    from Ohio
    It's not a good practice but I actually saw a guy drive a Z28 camaro 5 miles with no oil in the pan as the plug had come out. I have actually purposfully drained the oil from my car to pick up a tenth or so. But it had better be an important race!
