Started Buffing up the "Yard Find" 35 Ford Today!
Discussion in 'The Hokey Ass Message Board' started by James427, Nov 1, 2008.
  1. James427
    James427
    I can't believe how nice this thing is coming out and how shinney that black paint is under all that haze! Check it out!! I'm just going to clean this puppy up and run it! Got a flathead guy that's going to help me put the aluminum heads on and get it running so I don't screw things up too bad. I'm beggining to think I did pretty darn good on this car for the $7,000 I gave for it! :)
  2. Kustom7777
    Kustom7777
    from Austin, TX
    how cool.....that looks excellent,,,,,,you absolutely stole that car,,,,,,,,,,,,
  3. rebarsfords
    rebarsfords
    That ride looks like it's in great shape !
    Nice.
  4. t-buckethead
    t-buckethead
    from texas
    way cool!, when your done show the guy you bought it from.:cool:
  5. Jay71
    Jay71
    $7000.00 :eek::eek:. Thats grand theft! Looks great.
  6. Mr48chev
    Just a question from an old wrench twister. Why would you swap heads before getting it running and finding out what condition the engine was in? It seems like the productive thing would be to get it running and sorted out and see what you have and then swap the goodies on it.
    Nice looking car and it looks like you got a great deal.
  7. Searcher
    Searcher
    My hood has a split in the same place on the drivers side.
    I haven't quite figured out what caused it...except it's at the end of the hinge and maybe a stress point.
  8. sololobo
    sololobo
    How cool, man i love the 35 2-dr. You scored like the big bandito. That old paint looks like a million bucks, way to go brother. Enjoy that ride!!~Sololobo~
  9. James427
    James427
    The PO said that the cast iron heads were retaining heat on long drives and causing over heating. He had bought the correct (for 35) aluminum heads and had them totally refurbished and machined, bought a new gasket and nut set and had taken all of the stuff off of the engine to get it ready to remove the heads. Seems like it would be a good idea just to keep going to a) put the real purdy aluminum heads back on it, b) replace all of the gaskets, c) inspect the engine and valves while the heads are off and d) freshen up the block paint while it's apart. That is the current thinking anyway.
  10. 60'shotrod
    60'shotrod
    WOW!Nice '35,Great price!
  11. dudley32
    dudley32
    really nice...that must be lacquer to clean up like that...
  12. A Chopped Coupe
    A Chopped Coupe
    James427,
    Looks like the car was a "diamond-in-the-ruff". Looking really nice and I love the color of the wheels.
    When you get a chance send some pictures of the motor with the heads off. You mentioned the owner said "the cast heads were retaining heat"................it the car was overheating I doubt it was the heads. Do you still have the original cast heads, and if so how about a picture. When you get the heads off take a look at the water p***ages in the block, and did he get new water pumps to go along with the new "refurbished" aluminum heads. Flatheads can overheat, but not because the of the cast heads retain the heat...........there has to be another reason and maybe more experienced people of this forum can expand on this.
    Really nice, and I love the car, you did really good!
  13. solid
    solid
    You done good.
  14. gnichols
    gnichols
    from Tampa, FL
    Ya still wanna know what it's worth? Gary
  15. barney rubble
    barney rubble
    Man that paint looks great.:D:D:D
    Please do not screw it up by repainting it. Its only original once. After that its just a repainted car. JMO.
  16. James427
    James427
    The heads that have been on the car for years are still on it, so yes I have the cast heads. The two waterpumps are off and they look real good, but not new. Here is a pic of the engine the way I got it and the new aluminum heads.
  17. weemark
    weemark
    from scotland
    wow cant believe how well thats starting to look. it was worth every cent you gave the guy.
    if you are going to replace the heads I would replace the water pumps too, get the original ones rebuilt from skip haney http://www.fordcollector.com/water_pumps.htm no point putting heads on for it still to overheat and you need to start pulling the engine apart.
    I would also take the opportunity to run a high pressure hose down all the holes in the block to try and get as much of the silt out the block as is possible. on a flathead i just had built the rear two cylinders were completely encased in casting sand from the factory - its all cleared out now but i dont know how it ran cool when it was so full of sand.
  18. stude_trucks
    stude_trucks
    shiny old black, nice.
  19. NOTCH
    NOTCH
    James427, It's looking very nice and what are you buffing it with??
  20. FORD FAN
    FORD FAN
    Is this what people mean when they say.... "that'll buff out" ? Seriously, that's amazing!
  21. wvenfield
    wvenfield
    It's not like 50 people had to convince you of that. :D
  22. James427
    James427
    I just used one application of Presta Ultra Cutting Creme and a high speed buffer then wipped it with a cloth. When I'm done I'll go over it with a swirl mark remover and a foam pad. It should look wet after that.
  23. NOTCH
    NOTCH
    that baby look's real shiny like... Sweet
  24. James427
    James427
    Thanks guys for all of the encouragement and support. I'm going to need it because there is a whole lot of car to buff here. So many angles and edges and curves. I've never buffed a 30's car before!
  25. TraderJack
    TraderJack
    Am I the only one that sees that those are two different heads?
    traderjack
  26. Damn that thing is sweet !!! And yeah the heads have different chambers >>>>.
  27. chaddilac
    chaddilac
    Wow!! that is awesome! that has to have been the best deal posted here on the hamb I've seen!!
  28. Squablow
    Squablow
    I was really shocked at how many people were saying that this car wasn't worth the 7K the guy wanted for it, saying how ones in the same shape come along all the time for 3 or 4 grand. I don't think they knew what they were talking about.
    Buffed out and touched up, with new gl*** and engine running, this car is basically done. It doesn't need any more than that. Be sure to post pics when it's finished.
  29. novatattoo
    novatattoo
    from Canton,OH
    WOW Very Nice indeed!
    Later,Bill
  30. dmac620
    dmac620
    Amazing what a little "Elbow Grease" will get you. Nice score!
