Technical Starter/ ignition switch woes
Discussion in 'The Hokey Ass Message Board' started by Devin, Feb 8, 2026 at 6:55 PM.
  1. Devin
    Devin
    from Napa, CA
    Hey fellas,
    I should be watching the Super Bowl but got caught up working on my hot rod instead. I haven’t driven the car for a while due to work, life and weather. Last time I drove it I had no issues. Today, going to start the car I turned the switch and can only hear the ford solenoid click but no action from the starter. Tested the starter off of a jumper cable and all is good.
    Here’s the lowdown of the car:
    31 roadster
    327 SBC manual transmission, alternator
    Summit hi torque mini starter
    Rear mounted battery, battery fairly new and kept on a trickle charger during storage
    ****ery shutoff switch - functioning.
    Ford starter solenoid and switch mounted in close proximity to the battery.
    Battery cable runs to starter. Cable is heavy duty and appears to be in great condition.
    from what I can tell I don’t see any damaged wires or connectors (still need to go through it carefully)
    when I turn the key, the ford solenoid clicks but the actual starter does nothing.
    where should I look? Could this be the ignition switch?
    thanks in advance.
  2. Devin
    Devin
    from Napa, CA
    I recall buying the switch from SoCal years ago but it’s basically this style.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A little more info about how you jumped the starter. Like from where, did you only spin the starter motor with no flywheel ingagement ect.
    Moriarity likes this.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    If the solenoid is working , the ignition switch is likely OK. A dirty battery cable connection or ground could allow enough current to energize the solenoid, but not the high amperage draw for the starter...or the solenoid is bad.
  5. Devin
    Devin
    from Napa, CA
    Thanks guys. I tested the starter out of the car using jumper cables from battery to the starter. The ford solenoid is clicking but crickets at the actual starter and its solenoid. I don see anything obvious. I’ll have to get a test light or multimeter and poke around
  6. Kerrynzl
    Kerrynzl
    Run a jumper cable from the neg post of the battery to the block,
    Then try pos post of the battery to the solenoid/relay,
    Then try again from the solenoid/relay to the starter.
    To eliminate the possibility of the switch, jump a small wire from the 12v+ side of the solenoid/relay to the Ignition "S" side.
    If all is good but not with the ignition switch cranking , it could be the switch.
    You actually don't need a Ford solenoid/relay with a summit mini-starter , the starter already has a solenoid.
    You can connect this direct to the battery and the solenoid direct to the ignition.
    If you have used a Ford solenoid/relay "in-series" usually the solenoid on the starter is bridged ...... check this
