Customs Starter issues.
Discussion in 'The Hokey Ass Message Board' started by Scott71, Jun 3, 2021.
  1. Happydaze
    Happydaze
    What wire do you have to the neutral safety? I had a problem which sounds similar to yours and found I'd ****ed up on the NSS wire which despite carrying 12v wouldn't crank the engine. But it had worked fine for a year or so, then started to give intermittent problems (which seemed to be heat related) and I'd also swapped starters twice in the interim. Haven't had a problem since though! Not sure of the required wire gauge; I harvested the correct purple wire from an 80's GM loom I had for scavenging from. I recall it being significantly heavier than the lightweight piece of junk I had used (!) and was a bit surprised at the gauge of it. Not sure where my head had been when I'd originally wired the NSS in - the car didn't have one fitted when I acquired it, but that's another matter!
    Chris
  2. Scott71
    Scott71
    Hey Chris,
    Thanks for the input. Funny you mentioned the NSS wire seeming to be too small gauge for the job. I noticed that as well. Again, this was a complete engine and transmission swap so I needed new everything!!! The NSS wiring was barely larger than dental floss. That 31Vicky mentioned. I had no clue that was a possibility. It just seems like it could solve this problem for good. Move that darn solenoid away from the engine. As always, my fingers are crossed
