Technical Starter Motor Hookup
Discussion in 'The Hokey Ass Message Board' started by Sting Ray, May 26, 2019.
Tags:
  1. Helping the neighbor kid get his '64 El Camino running but don't know where to hook up a couple wires on the starter. There's two terminals one marked S and the other R. The wires are wrapped in a loom so tracing would be difficult. If they were to be hooked up wrong, what's the consequence? Maybe nothing? Then switch the wires?
  2. sdluck
    sdluck
    do you have a volt meter or a test light?S should have power with the key in the crank position,
    Sting Ray likes this.
  3. Yes, have both. Would the energized wire go to S then? This is on a 327 btw.
  4. S goes to the starter switch, R goes to the ballast resistor to byp*** it when cranking.
    (Coil side of the resistor).
    Truckdoctor Andy and Sting Ray like this.
  5. lostone
    lostone
    from kansas
    Gm, the R goes straight to the + side the coil. A full 12 volts during cranking to help fire the engine.
  6. Black Panther
    Black Panther
    from SoCal
    On many GM cars the fatter purple wire is the one for the S terminal...
    Sting Ray and squirrel like this.
  7. squirrel
    S wire is purple, R wire is yellow, if they are original wires.
  8. It's been spliced in but that's good info to have.
