Technical Starter rebuild question
Discussion in 'The Hokey Ass Message Board' started by StefanS, Jan 18, 2017.
  1. Ship it to me. I got a 3 bolt starter here that is in good enough shape for parts. Between the two of them we can make you a good starter. Probably cost us shipping and maybe a couple of bucks, have you going again in a few days (I'm slow).
  2. StefanS
    StefanS
    from Maryland
    I truly do appreciate that. Thats one of the things I love about this site. I have the napa starter on order already and it has a lifetime warranty so I'll be covered for a while.
  3. squirrel
    3 bolt starter would be 12v, eh? the parts don't fit....
  4. StefanS
    StefanS
    from Maryland
    I was wondering about that but I don't know enough to question it
  5. StefanS
    StefanS
    from Maryland
    So here's what we're looking at. To start off, my car had the wrong starter. From my research, i found out that the powerglide starters came with 4 field coils and the manual cars came with 2. I only have 2. Two of the four brushes are completely worn out. How that could happen to only two, I have no idea. Also, the fiber material I was talking about covers the field coils. One of the covers is torn. There's also a ton of grit and grime in there. It was surprisingly easy to re***emble however. All the pieces were pretty much self explanatory and nw it's one unit again. Does anyone with one of those books that gives all part numbers feel like seeing what the number for the field coils is? I found a bunch on ebay for between 20-40 dollars. Brushes I can get on Rock auto for like $4 for the set. I tried to upload pics but it's not letting me for some reason
  6. Ooops missed the 6V part. :oops:
    squirrel likes this.
  7. squirrel
    TOMCP is down...bummer!
    http://chevy.oldcarmanualproject.com/
    2.049...coil ***y, starting motor field
    1921195 and 1921196 should be them, right and left
    the upper and lower for the PG type is 826282 and 8262821
  8. StefanS
    StefanS
    from Maryland
    Ah, thank you sir. So do you think I can take a two field coil starter and add the extra two to make it a four field coil starter, or are there other internal differences as well?
  9. StefanS
    StefanS
    from Maryland
    Here are those pics Screenshot_2017-01-20-09-04-45.png Screenshot_2017-01-20-09-04-41.png Screenshot_2017-01-20-09-04-49.png
  10. StefanS
    StefanS
    from Maryland
    And here's the Napa starter. I really wanted to keep my money local and help an independent, small business, but at almost double the price of what this one costs, I didn't have much choice. This starter cost $106.64 out the door and I get to hang on to the old starter. The only thing is, it's rebuilt in me-he-co but at least it's connected to us right? Lol Screenshot_2017-01-20-09-14-50.png Screenshot_2017-01-20-09-14-56.png
  11. squirrel
    I would just clean it up as best you can, and replace the brushes, and put it back in...but I am a lazy cheapskate.
    (I would not suggest adding more field coils, unless you also make sure the rest of the starter is the same as the one that came with 4 field coils, which according to my book was used on 55 Corvettes, but not on the powerglide equipped p***enger cars)
  12. squirrel
    does the gear on the rebuilt starter look the same as the gear on your old one? same size teeth, etc?
  13. StefanS
    StefanS
    from Maryland
    Here's a couple more Screenshot_2017-01-20-09-15-00.png Screenshot_2017-01-20-09-25-38.png
  14. StefanS
    StefanS
    from Maryland
    Yeah, it looks identical. It also came with the solenoid which the $168 rebuild wouldn't have so that could potentially have saved me another $50-$60 on top of the $70 it already saved me.
  15. StefanS
    StefanS
    from Maryland
    Chev235guy.blogspot.com is where I got the info about the different starters.
  16. squirrel
    maybe I read the book wrong?
  17. StefanS
    StefanS
    from Maryland
    It looks like it's saying '50-'54 p***. w/ pg and '54-'55 corvette has an upper and lower
  18. squirrel
    yup. But the corvette don't have a left and right.
    Very strange...
  19. StefanS
    StefanS
    from Maryland
    This is true. I suppose it doesn't matter too much anyway, since I'm switching to a manual trans so I won't need the extra field coils anyway. I just hope this one lasts until I get it in. I'm still looking for a garage to do the swap
  20. squirrel
    they do seem to all use the same armature.
    Did you peek inside the new starter and see how many field coils it has?
  21. StefanS
    StefanS
    from Maryland
    I haven't, but now I want to.
  22. You are correct but the FJ and FK exceptions, ???
    Do you have the chart in the Parts Catalog that decodes that? I used to know a lot of those codes but I have forgotten them.
    I used to have a 29-54 parts book that I found at the first dealership I worked at in 1970 but gave it to a friend a few years back. I know he sold the car since then. I just saw him at a memorial service on Sunday, should have asked him if he still had it.
  23. squirrel
    FJ and FK are 1948 models
  24. StefanS
    StefanS
    from Maryland
    The starter has 2 field coils. I'm thinking about putting some "Right Stuff" rtv around the edges of the commutator cover band, to seal it up really well
  25. squirrel
    I would not....
  26. StefanS
    StefanS
    from Maryland
    Any particular reason? I just figured it covered the brushes and all
  27. squirrel
    It should be fine the way it is. You don't plan on fording rivers or anything, eh?
  28. StefanS
    StefanS
    from Maryland
    Nah, no rivers for me but you should've seen the crud that started dripping out when I took the band off the old one.
