Technical Starters Question
Discussion in 'The Hokey Ass Message Board' started by greg37, Nov 25, 2024.
  1. greg37
    greg37
    from mi.
    What is that attachment from the starter to the solenoid ? I might have wired the new starter wrong. It's a Chevy starter and I connected the purple ign. switch wire to the S terminal but after getting it installed I can turn the Ign. switch and the starter does nothing like the batt. is dead, if I keep moving the key it does turn over a couple of times but then back to nothing again. I really can't remember if that purple wire went to that bottom attachment or not. Thanks Everyone
    Sharpone and chryslerfan55 like this.
  2. patsurf
    patsurf
    you have to use purple as trigger wire to solenoid and the other one as reistor by-p*** on the other term
  3. Kevin Ardinger
    Kevin Ardinger
    What other wires do you have? IGN. on the starter is ignition ballast byp*** in crank position. Should go to the coil. S term on starter should go to S on ign switch. That loose screw on the bottom of the solenoid is a big problem as well.
  4. squirrel
    Yup, that long screw that goes through the spacer, is what carries the current from the solenoid to the starter windings. If it's loose like that, it won't work very well...
    Sharpone and 41 GMC K-18 like this.
  5. greg37
    greg37
    from mi.
    I have installed a new starter, The picture is of the old one I loosened the screw . The problem started after I installed the new starter that's why I thought maybe that purple wire went to that lower attachment instead of the S term.
  6. Kerrynzl
    Kerrynzl
    Always bench test a starter before installing it .
    Some jumper cables and a piece of wire is all you need.
    It saves a lot of grief.
    On the solenoid "S" goes to the ignition switch and "R" goes to the coil.
  7. greg37
    greg37
    from mi.
    Thanks for the picture, I do have it wired correctly then. Now to find out why it acts like the batt. is dead and if I continue to turn the key on and off it might turn over a few times but then go back to acting like a dead batt.
  8. Kevin Ardinger
    Kevin Ardinger
    Sounds like a poor connection somewhere. Battery connections, ch***is grounds??
    Sharpone, Kerrynzl and 41 GMC K-18 like this.
  9. Kerrynzl
    Kerrynzl
    Run a jumper cable direct to the starter [main cable] then try it.
    Then a jumper cable direct from neg battery to the engine [ground cable] then try it.
    Then try and short the "S" with a screwdriver or another piece of wire
    That is why I bench test first [to eliminate the starter as a problem]
    Sharpone likes this.
  10. greg37
    greg37
    from mi.
    Not sure about how to short the S connection post ?
  11. patsurf
    patsurf
    feed it
  12. pprather
    pprather
    The ignition switch may be bad, or have a bad connection.
  13. greg37
    greg37
    from mi.
    What has me stumped is the car would start but it had a bad starter that had some worn teeth on the starter gear. So that's when I bought a new starter installed it and this story started.
  14. jaracer
    jaracer
    This is a perfect case where conducting voltage drop testing will pinpoint the problem. Do you have a digital voltmeter?
  15. greg37
    greg37
    from mi.
    No, on the voltmeter.
  16. Damon777
    Damon777
    You're gonna want to pick up a DMM (digital multimeter) before you get too far down this rabbit hole. You can get a p***able unit pretty reasonably priced. Bonus if it is an "automotive" unit that has dwell and such as you may need that in the future. I grabbed one at Menards recently for $30 or so. No, it's not a heirloom (fluke), but it tells me what I needed at the time.
    Check voltage at the battery to make sure you have 12 or so.
    Then I work backward from the starter, personally. Unhook the sire from the S terminal, and run a temporary wire from that to near the battery. If the starter turns the engine over when this wire touches B+, then something is bad between the S terminal and the battery.
    Now connect your DMMs + lead to the factory S terminal wire and the - lead to ground (B-, the engine block, etc.). Set the DMM for DC voltage. See if your meter reads 12V when the ignition switch is turned to the Start position. If no voltage there, check the wire feeding the ignition switch for battery voltage. Keep working your way back from component or splice until you find where you have battery voltage.
    If you have voltage to the ignition switch input terminal, but no output, you can disconnect all of the wires from the switch and use the resistance (Ohms or Ω) mode to see if there is continuity between the input (battery) terminal and whatever terminal feeds the various wires.
    Early automotive electrical systems aren't super complicated. If you can find the wiring diagram for your car it makes it even easier. Take your time and be methodical. This will keep you from being one of those "pluck and chuck" guys who just swap out parts without knowing why or even if said part may be bad.
    Sharpone, 38Chevy454 and pprather like this.
  17. greg37
    greg37
    from mi.
    Great advice, Thank you !
    Sharpone, lothiandon1940 and Damon777 like this.
  18. 1971BB427
    1971BB427
    from Oregon
    Bad solenoid on the new starter. Bet if you swapped the solenoid from the old starter to it the starter will work. But really should just take it off and return it for warranty.
  19. greg37
    greg37
    from mi.
    I just took the starter off and bench tested it and it worked great, I know a starter is grounded when it's bolted to the engine but I noticed it looks like it has an aluminum mounting block , Does this somehow need a ground to the engine ? If not I'm thinking maybe the ignition switch may be bad ?
  20. jaracer
    jaracer
    Go to Harbor Freight and get a cheap digital voltmeter then you can test and not guess.
    Sharpone, pprather and Damon777 like this.
  21. Kerrynzl
    Kerrynzl
    Use a screwdriver across the Main Feed and "S" terminal
    like this.
    Not that I know...... But the rumour is car thieves have been doing this for years :p [before steering locks and slide-hammers]
    You can test the starter in place with a piece of wire with 2 alligator clips.
    But do as what @jaracer suggested and buy a cheap H/F multimeter [you should have one in your ****nal anyway]
    On our 57 Chevy there was 12volts at the "S" wire but it barely cranked [similar to heat soak issues]
    Load testing showed almost zero current.
    It turned out to be a melted wire between the Ign switch and firewall under the dash.
    This was surprisingly easy to replace / rewrap [from the firewall side]
    Do a voltage test on the "S" purple wire [red to purple and black to ground]
    If no voltage that is your problem.
    If there is voltage, then select Amps "and use the correct posts on your multimeter"
    Then connect these in-series with the "S" terminal and "S" purple wire [so the load goes through the multimeter] then try and crank it.
    This will show you Amp draw.
    One last thing , make sure the battery ground wire is connected directly to the engine block [and a secondary ground to the body]
    GM used star washers under the ground and main 12v feed cables
    clem and Sharpone like this.
  22. greg37
    greg37
    from mi.
    Yes the battery neg. is attached to the engine. Iv'e already determined the starter is good by the bench testing so your saying I'd be checking for a bad wire or the ignition switch ?
  23. Budget36
    Budget36
    In your bench test of the starter, does it spool up to speed, or torque the starter over? It should torque the starter over.
  24. Kerrynzl
    Kerrynzl
    It can also be the main 12v H/D cable from the battery to the starter. But a quick "short" with a screwdriver will confirm/eliminate that.
    If that is OK and you test the purple wire and it appears to be a problem. Then unplug this from the Ign switch and measure resistance of the whole wire [from each end]
    The resistance should be close to zero.
    I've made up a few wires with Male / Female spade terminals on each end so I can power up the Ignition switch with the main plug removed. [connect the 12v feed "in-series"]
    You can go through the switch spade terminals with the multimeter checking for 12v when on ,and cranking position "S" .
    Apart from wires being melted near the switch, the other problem I've encountered was dirty connectors which I clean.
    A fine scotch pad soaking in Isopropyl alcohol gets them clean
    I give the male spades on the back of the switch about a 3° twist with needle nose pliers.
    This is enough to pre-load the terminals for a good connection. [ because sometimes the females are loose in the plastic plug]
  25. Sharpone
    Sharpone
    Also if using a screwdriver or even a wire to jump at the starter try to not touch the studs as this can and will damage the threads, touch the nut flats instead.
    Dan
    clem and Glenn S like this.
  26. greg37
    greg37
    from mi.
    This is all very good information, I hope this is helping others as well.
