Hot Rods Starting a T-Bucket with some nice parts.
Discussion in 'The Hokey Ass Message Board' started by Frames, May 1, 2022.
  1. Frames
    Frames
    Customer from Maine arrived last week. Said "let's build a T-Bucket chassis". He helped 5 days. We got pretty much done. He did the lighting holes and the welding. I had the front axle, spindles. brakes and spring in stock. I built the FRANKLAND quickchange one day before he arrived. I used 36 housings and heavy wall 1940 front bones. He has a 1/2" SCAT stroker Flathead that I built last year. Other neat parts he has. SCHROEDER steering, THICKSUN 4 carb intake, 1937 PACKARD trans and a GENUINE 23 T body from California no less. Sharp eyes will see front spring hangers, rear Heims not double shear and lower gusset to reinforce the tube to 36 spring mount weld not finished. We used what I had on hand. The dropped tie rod ends work out well. 2022-04-29 21.25.14-5.jpg 2022-04-29 21.25.14-1.jpg 2022-04-29 21.25.14-2.jpg 2022-04-29 21.25.14-3.jpg 2022-04-29 21.25.14-4.jpg
    mitch 36, vtx1800, Petejoe and 27 others like this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    Great start:D:cool:
    VANDENPLAS, hrm2k and Blues4U like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Man, that looks good. HRP
    VANDENPLAS likes this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Looks great Dennis. Professional job there and parts to die for.
    Keep us updated.
  5. fiftyv8
    fiftyv8
    from CO & WA
    What tie rod ends are those pictured?
    I may find them useful soon.
  6. $um Fun
    $um Fun
    from Nor Cal
    Looks like 37-39 Willys tie rod ends.
  7. Max Gearhead
    Max Gearhead
    from Wisconsin
  8. Frames
    Frames
    Ford pick up. I purchased several years ago from Speedway. #910-48640.
    Tim likes this.
  9. HotRodTodds
    HotRodTodds
    This won’t be your typical grandfather’s T-Bucket!
    Kelly Burns likes this.
  10. BrerHair
    BrerHair
  11. Cooooool man , keep us posted on the progress , gonna be neat -o to say the least !!!!
  12. Frames
    Frames
    Todd [ owner from Maine ] and I put 4 days in the T chassis last week. First on the agenda was to adapt the Packard trans to the flathead using a Chevy to Packard adapter. I flame cut a 5" diameter x 5/8" thick ring. Machined it to locate the trans to the bell housing. Drilled some new holes in the bell housing. Fabricated lower rear shock mounts. Mounted the trusty old F 1 shock mounts in front. Fabricated 3 position lower shock mounts. Going to use 820D headlights. That is a smaller park light than the cookie cutter ones more readily available. PS; We need one more 820D. If only the park light or a pair. What ever you got. Fabricated an adjustable front spring perch. The front engine mount 2023-03-19 22.15.25-2.jpg 2023-03-19 22.15.25-3.jpg 2023-03-19 22.15.25-4.jpg 2023-03-19 22.15.25-5.jpg 2023-03-19 22.15.25-6.jpg 2023-03-19 22.15.25-7.jpg 2023-03-19 22.15.25-8.jpg 2023-03-19 22.15.25-9.jpg 2023-03-19 22.15.25-10.jpg 2023-03-19 22.15.25-11.jpg 2023-03-19 22.15.25-12.jpg is magnesium plate.
  13. Spooky
    Spooky
    !!!!!!!!!! WOW!!!!
    Kelly Burns and dana barlow like this.
  14. dana barlow
    dana barlow
    from Miami Fla.
    Liking all of that,looking real good,neat an clean. Only thing I'd do def. except motor n tranny mounts having no rubber in them! I've always been fine with race cars having solid mounts, high maintenance ,just not a fan for street drivers. Long as things are looked at often,the extra vibs prob. can be looked after,though.:cool: Coming along great.
  15. Frames
    Frames
    Back home in Vermont. Todd reports the engine location and body mounted worked out great. Sure wish I had pictures. He's working on a 36 roadster right now.
    dana barlow likes this.
  16. Rickybop
    Rickybop
    Glad you brought this back up so I can see it and learn a couple things.
    I pay attention.
    And you're a good one to pay attention to.
  17. Rickybop
    Rickybop
    @Frames ...
    You got a minute to give me just a quick run down of Franklin vs Halibrand vs Winters?
    Or anybody else, too. Thank you.
  18. RodStRace
    RodStRace
  19. 1pickup
    1pickup
    Always impressed with your work, Dennis. Keep it up!
  20. Frames
    Frames
    Kelly Burns, patsurf and AndersF like this.
  21. Frames
    Frames
    4 U 2 C
  22. Frames
    Frames
