Technical starting an 8BA after sitting 36 years
Discussion in 'The Hokey Ass Message Board' started by kls50, Aug 6, 2022.
  1. STARTING AN 8BA AFTER SITTING 36 YEARS
    After reading the ***le my first thought was "you need to see a doctor asap, worry about the car later". :eek::rolleyes:;):D
  2. kls50
    kls50
    I'll get an appointment scheduled tomorrow! HA! HA!
    borntoloze and chryslerfan55 like this.
  3. kls50
    kls50
    Well, after seeing my Dr. last week, I'm back at it. Prognosis is good! Only a few s****es, bruises and a sprained wrist, nothing broken. My dogs got tangled up in my feet and I fell over like a big old oak tree! Anyway, I rebuilt the carb and fuel pump and reinstalled them. Also, I replaced the coil, points and condenser, cap and rotor along with the wire from the coil too the distributer. No spark! After looking for the problem Trouble shooting, I found the problem. When I tightened the screw with the ground wire that secures the points, the ground wire turned with the screw and made contact with the points, shorting them out. I'm putting the plugs back in and connecting the plug wires back on today. Getting closer to starting the old girl up!
  4. kls50
    kls50
    Yesterday I installed the radiator hoses and ran a fuel line to the pump. I put 2 gallons of antifreeze in the radiator. I added an ounce of Marvels mystery oil to the fuel and primed the fuel pump. I checked for leaks-none! Today, the big day, is finally here! After a few tries, it popped off for about two seconds! I set the choke on, pumped the throttle a couple of times and walla! Just like that, She's Alive! I'll try to post a video of it later. Oh yah, no blue smoke! The water pumps are a little noisy.
  5. kls50
    kls50
    After a closer inspection, the right water pump is a little noisy, the left water pump doesn't turn at all. Hence the smell of rubber burning. I am going to rebuild both water pumps as soon as I get a 10-ton press from good old Harber freight. I have three 1950 ford coupes. Only one that runs. I want to get the one in my avatar painted. but I don't want to have nothing to drive as it gets blown apart and painted. I LOVE getting these old 1950 Ford coupes on the road and I would save every one of them I see that is sitting in a field, or for sale! I Love the 1950 Ford Coupe!
    gary macdonald likes this.
  6. alanp561
    alanp561
    FWIW, I just bought two new water pumps for my 59AB from Mac VanPelt way cheaper than Speedway. I was going to rebuild the ones I had but VanPelt's price was just a couple dollars more , with ceramic seals, than a rebuild kit and I didn't have to do it.
    Desoto291Hemi and Budget36 like this.
  7. kls50
    kls50
    Thanks, I will check them out for sure! I have more I need to rebuild, but I if the price is right-no brainer!
  8. dmar836
    dmar836
    I would love to see the pan dropped in the meantime. It's not that many bolts. I would love to hear, "See, no garbage in there!" I would almost bet money there is at least **** in the screen but most likely sludge sitting in the pan. Less and less need to avoid this simple task, especially if you are delayed for other upgrades.
    Ran into a buddy at a show today with an old original T I helped get started this spring. It had been stored indoors in a showroom. All looked good and even so after an oil change and 20 miles. He saw the screen was dirty this am and rushed all morning before the show to pull the pan and remove all the sludge not evident at first. I told him I would never run one again without that simple preventative procedure. He had to admit it would have been the right thing to do. I think he got first today.
    A) I want success for you long term(not just to see it run - I know it will.)
    B) I want to be proven wrong! Please prove me wrong and I'll owe you a favor.
    Best of luck,
    D
    alanp561 and leon bee like this.
  9. kls50
    kls50
    Well, I bought two water pump rebuild kits from Vanpelts a month ago. My friend told me he would rebuild them for some parts he needed. Long story short he broke the impellers while trying to press them on and then one of my pulleys could be put on by hand(loose). I gave up on them and found a pair (of pumps) on Ebay for $75.00 with shipping included. Rebuilt but sitting on a shelf for years. I cleaned and painted them and installed them last week. I removed the thermostats a couple of days ago and cleaned and painted the housings last night in my ba*****t. Too cold outside. I plan on buying a camera scope to look in the pan and oil pump screen and pulling the intake off to take a look and paint it also. My plans are to get the car road worthy and leave the body just as it is. I will pull the pan if it needs cleaned out. Also, to paint it. Lipstick on a pig
    rusty valley likes this.
  10. Pull the heads and Intake, fill the lifters/cam and piston rings with 50-50 mix of acitone and ATF. Let ir sit till it drains thru, tap the open valves with a plastic hammer turn the engin Tap the rest of the valves to loosen then all. Turn the engine over by hand to free up the rings in the bores. drain all the oli mixture out and add 50 weight oil, thru the cam opening to oil up the cam good turn the engine over 5 to 10 revolutions. put it back together and fire it up.
  11. kls50
    kls50
    I got the thermostats in a couple of days ago. 160 degrees with two 3/16 holes drilled at 12 and 6 o'clock as suggested by Shoebox Central. Pics of the old ones I removed.
  12. kls50
    kls50
    This video is from Sept. 2, 2022.
  13. kls50
    kls50
    This is also on Sept. 2, 2022
  14. dmar836
    dmar836
    Cool. What was that squalling? Didn't sound like a belt to me.
    How many miles does it have on it as of this time almost a year later?
    D
  15. tubman
    tubman
    Did you notice what you had for oil pressure? For me, that would indiicate the next step with the engine. From what I can see, the car looks pretty solid. In the short glimpses I did see, there didn't seem to be any large rust holes and the grille looked good.
    I have a '51 club coupe and I really like these cars.
  16. 19Fordy
    19Fordy
    Fantastic. Well done!
  17. kls50
    kls50
    The coupe has 79, 000 miles on it. The squealing was a belt sliding over a stuck water pump and the other one was squealing as well. I replaced the water pumps, thermostats, coil, points, starter switch, oil, filter. ground strap and a few other small items. I rebuilt the carb and fuel pump. I removed the radiator hoses, radiator, generator, belts and fan ***embly last fall. Yesterday I rigged some br*** fittings together and installed a mechanical oil pressure gauge. I filled the fitting that screws into the oil filter can with solder and drilled a .0595 hole in it for the restrictor fitting (Irwin drill bit #53). As soon as I get the radiator cleaned out and reinstall the belts hoses generator and fan. back on I am going to check the oil pressure.
    rusty valley and leon bee like this.
  18. kls50
    kls50
    I couldn' wait to put the cooling system back together. The oil pressure was still coming up when I shut it off. I only ran it for about 30 seconds.
  19. y'sguy
    y'sguy
    from Tulsa, OK
    Thanks for posting and showing all the details of your process. Very helpful to others. All this great care should make for solid rescue of this flatty.
    Could you explain why you felt it was necessary to use a restrictor fitting?
  20. kls50
    kls50
    I posted a thread (8ba low oil pressure/restrictor fitting) From what I understand the restrictor fitting allows the oil pressure to remain high in the engine and the oil pressure in the oil filter canister to be reduced helping to keep the lid from blowing its seal and leaking. Hope this helps.
  21. rusty valley
    rusty valley
    I'm gonna guess that most of the old canister / byp*** systems used a restrictor, not just Ford.
