Technical Starting engine on stand.
Discussion in 'Traditional Hot Rods' started by Donuts & Peelouts, Sep 4, 2017.
  1. Flathead Dave
    Flathead Dave
    from So. Cal.
    No. It was his stupidity of his showing off ability.
    els and Donuts & Peelouts like this.
  2. southcross2631
    southcross2631
    I have mufflers for my stand. I was showing the stand not my exhaust system.
    els likes this.
  3. Jim, You run it at night, with all the lights off, right? Coool!
    els, Donuts & Peelouts and squirrel like this.
  4. bobbytnm
    bobbytnm
    I take it you're going to start that big Caddy?
    Those big Caddys were made with a big high iron content so they are pretty durable. They can take a lot of abuse. The pics I saw of you engine in the other thread looked pretty clean. I'd clean it up and paint it, maybe change the timing chain because its easy when its out of the car.
    You can make a decent engine stand from some 2x6 lumber that fits on either side of the oil pan to support the block.
    Here's my old Packard firing in my garage on a makeshift stand made from some lumber and wheel dolly (click on the picture)
    els likes this.
  5. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Bobby, thanks Bud. Yes I'm gonna try to start this beast. Most likely on a a tire tied down I'm ghetto like that. Lol , so Glad when chevy57dude said 'it'l run on dirt".
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
    els likes this.
  6. Mr48chev
    Jim already answered it but an engine doesn't need an alternator or generator to run.
    Most of the Central Texas dirt track racers who ran at Heart-O-Texas speedway in the 70's didn't have any kind of charging system on the car.
    Fully charged battery at the start of the night and as they only had to start it and operate the Ignition the batteries normally made it though the whole night running a heat or two and the main without problems.
  7. ClayMart
    ClayMart
    Not only is this guy fun to watch, but he's surprisingly methodical in his approach to testing out an "unknown" engine. He doesn't just throw money at it until he knows what he's actually working with. He makes a lot more sense than the average Utube clown.
    There's several videos
    in this particular series and they're all worth watching, especially when the engine comes to life.
  8. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks so much Clay. I'll be subscribing to him, I appreciate that because it saves me time sifting through the "clowns" as you say.
    els likes this.
  9. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Mr48chevy that's cool info to know . As far as a compression test AFTER you run it for a while. WHY??? what's the theory behind checking compression on a warm engine apposed to a cold one?
    els likes this.
  10. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    I feel like the Hamb has helped me so much, I owe people in so many different states beers
    Sage Youngblutt and els like this.
  11. You could do it before and after if you want, but if it's been sitting for a while, you'll want to run it and get oil up in the cylinders and between the rings and get some of that carbon out of the way first.
    First thing, you want to look at the plugs before you do anything. If they're uniformly beige or brown, even with some build up, you should be good to go. If one is black, it could be just a plug or wire problem. If it's black and wet with oil, pay close attention to that cylinder on the compression test.
  12. ClayMart
    ClayMart
    Make it easy on yourself... :p
  13. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Now that's a fax machine!..But wow man that man's videos you shared with me are putting me on a higher level of understanding. I'm stuck on his channel. Thanks Man.
    els likes this.
  14. BigDogSS
    BigDogSS
    from SoCal
    Be aware --> the youtube guy with the Pontiac does not actually start the engine until episode 4, and only with starter fluid and no carb.
  15. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    els likes this.
  16. henryj1951
    henryj1951
    from USA
    Sweet* that's how i built mine(s****) have build MANY they never come out quite the same ...lol
    els likes this.
  17. Mr48chev
    Mark Yak pretty well nailed it on running the compression test after running the engine for a few minutes.
    It helps get things unstuck a bit and may give a more honest compression reading. That Cad 500 had sat in the ambulance for several years without being driven. Got driven around the block a couple of times before my buddy pulled it and then sat under a tarp in his yard for at least a year before he got tired of looking at it and gave it to me.
    Donuts & Peelouts likes this.
  18. You should see this thing go when he puts the propeller on it..............
  19. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Hey guys the other day I bought a engine and transmission for 35 bucks.. it was a Toyota but I plan to use it as a core in the junkyard, anyways when I got home I had no idea where to put it because I only have one engine stand and already have an engine on it. So I remembered something from this thread, the shopping cart. I came home the next day with a metal shopping cart and put the engine straight in there it was perfect. Well I ended up selling the engine and transmission for 120 bucks.
  20. indyjps
    indyjps
    You can get real basic with a fat tire, gas can, battery.
    Ive made a few of these, for basically zero money, used radiator out of whatever, make sure hoses are on correct sides, cheapy guage panel from junkyard. Angle iron from wherever. Doesnt have to be pretty.
    I was rebuilding a lot of sbc's at the time and was breaking in cams, so I needed run time. Used a running engine to set it up the first time and trouble shoot the stand.
