Technical Starting issue
Discussion in 'The Hokey Ass Message Board' started by desotoman53, Feb 29, 2020.
  1. desotoman53
    desotoman53
    from Conroe
    Not sure if I post tech questions here but going to ask. I have an in-line 6 Chevy 250 motor and a one barrel carb. I have it fire up but as soon as I let go of the key it turns off. I’ve checked to make sure I was getting 12v after the key is let go and I am. Just seeing if anyone could help thanks.
  2. goldmountain
    goldmountain
    302GMC and Moon50F3 like this.
  3. fastcar1953
    fastcar1953
    do you have 12v at coil and dist.?
  4. desotoman53
    desotoman53
    from Conroe
    I have a 12V HEI dist. I just found out if I hold the pedal down it will run for a little while.
  5. desotoman53
    desotoman53
    from Conroe
  6. desotoman53
    desotoman53
    from Conroe
    Yes I verified with a multimeter.
  7. Doublepumper
    Doublepumper
    from WA-OR, USA
    Distributor clamped tight...slipped time? Vacuum leak? Got fuel?
  8. harpo1313
    harpo1313
    from wareham,ma
    Was this a running motor?
  9. desotoman53
    desotoman53
    from Conroe
    Got fuel timing still good. Now I no longer have to hold the key I have to keep pushing the pedal or it will die.
  10. Doublepumper
    Doublepumper
    from WA-OR, USA
    Starting to sound like a lack of fuel delivery somewhere, tank, pump, filter, plugged up carb p***ages...?
  11. desotoman53
    desotoman53
    from Conroe
    I’m going from a van to the pump to the carb. I’ve removed the line to the carb and turned the ignition and fuel was coming out.
  12. tb33anda3rd
    tb33anda3rd
    sounds more like a big vacuum leak.
    VANDENPLAS and Boden like this.
  13. desotoman53
    desotoman53
    from Conroe
  14. King ford
    King ford
    from 08302
    How does it run when you hold the key in the " on" position?( you can hold it in "start" for 4 or 5 seconds after it does indeed start)??....als sometimes if you " let go" of the key after the engine starts the springload of the " return from start" feature of some ignition switches will cause the switch to " rotate past" the run position of the switch thus cutting the electricity to the coil.....
    Boden likes this.
  15. Mr48chev
    It sounds like you have the resistor byp*** wire wired to the HEI and need to wire it to either the wire that lead to the ballast resistor originally or to a hot when ign is on pin on the fuse block.
    You still may need to keep the byp*** wire hooked up simply because there are some ignition switches that don't have power to the coil in start position depending on the byp*** wire when cranking.
  16. Sound like this.
    New build?
    New issue?
    Running engine?
    New engine?
    Change any parts and this problem started?
    ya got fuel, do you have spark at the plugs? Fat blue or orange spark?
    I would be looking at a vacuum leak.
    Any vacuum lines ya got remove and plug and see what happens .
    report back please .
