Starting issue
Discussion in 'Off Topic Hot Rods & Customs' started by Bob Bagley, May 26, 2025.
  1. Bob Bagley
    Bob Bagley
    Working on Ford in line 6 cyl. with points distributor, the engine started and ran fine one day and wouldn't start the next. I checked the points and there was no spark when separating them, I used a test probe light and have current to the coil with the key in run position but none going to the distributor. I tried another coil with same results.. Is there anything else I should check before spending the money on a Pertronix system? Thanks.
  2. Bandit Billy
    Bandit Billy
    Pretty simple stuff. Check the condenser yet?
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    use your testlight on the dist side of the coil while someone cranks it over. the light should flash. if it doesn't then file the points
  4. gene-koning
    gene-koning
    I have seen times when the wire from the coil into the distributor fails as it p***es through the distributor case. The power from the coil never makes it to the points. Check to see if you have power getting to the points.
    Speccie and Moriarity like this.
