Steadfast Chassis: READY TO GO
Discussion in 'Parts For Sale' started by Steadfast mfg, Apr 30, 2025.
  1. Steadfast mfg
    Steadfast mfg
    City: Bellville
    State: Ohio
    Price: $12,500
    You dont get a second Stance to make a first impression... So, with that being said, who's ready for a Steadfast 1932 Ford highboy ch***is??!
    We decided to tool up and build a simplified version of our high-end 1932 Ford highboy ch***is. Same Stance, Ride Quality, and Parts. The 3/4 front wheelbase stretch and pinched rails will make everything look ***y around the grille shell! We left the motor/trans and pedal ***embly mounts out so you can run any combo! All parts are Steadfast, Shadow rods, Pete and Jake's, So-cal/ Roadster supply. We built 4 frames and have only 2 left. One coilover and one buggy sprung. What you see is what you get. $12,500
    Shadow rods frame rails with Steadfast Cross Members
    Steadfast Parts:
    rearend brackets
    rear pan hard
    front pan hard
    steering box mount
    thru frame bungs
    misc tabs
    Roadster Supply:
    5" dropped axle
    hairpins
    GT2 shackles
    GT2 pitman
    Borgeson Vega Box
    Tie rod Kit
    drag link kit
    adjustable perches
    steering arms
    king pin kit
    9" rear with axles
    Pete and Jakes:
    rear ladder bar kit
    rear spring
    Durant:
    Super low spring
  2. Steadfast mfg
    Steadfast mfg
    Steadfast Ch***is: READY TO GO
