Technical Steady Rest motor mount Y-block
Discussion in 'The Hokey Ass Message Board' started by don v., Dec 21, 2020.
  1. don v.
    don v.
    I have a 55 Ford Country Sedan that I have installed a 272. During install I reversed the mounting block on the Steady Rest so the 2 bolts are not resting on mount but are in fact captured by the metal block. I know this is incorrect, but I wonder what effect will it have on its purpose? It seems really not needed? or did the Ford engineers over engineer??
    Thanks
  2. jimmy six
    jimmy six
    I took mine off 2 years ago when replacing the balancer/damper. If you ever install a transmission that needs a lower tank cooler it sure makes it easier to not have it there.
    Ford also removed it in later years with out a problem. Many agree with your overengineering. I believe you must remove the damper to remove it. I also cut off the frame mount and smoothed it over.
    There is a lot of information on the Yblocksforever.com site.
  3. AldeanFan
    AldeanFan
    I left it off when I put the 292 in my Country Squire. 3 years and a few drag strip p***es and it hasn’t caused any problems.
  4. junkyardjeff
    junkyardjeff
    I think 56 was the last year for them.
  5. don v.
    don v.
    Thanks all for replies, I won't sweat it how incorrectly it was installed then, if it becomes a problem I'll remove the two bolts holding it in front frame mount.
