Technical steel fuel line question ???
Discussion in 'The Hokey Ass Message Board' started by furyfan, Oct 20, 2015.
  1. furyfan
    furyfan
    from MA
    Does anyone if there is a place that sells a tool to form the ends on steel fuel lines like the one pictured? It makes for a nice non-slip connection when the rubber hoses are connected. Thanks for[​IMG] any info here.
    John
  2. You can get a formation that does the same thing but doesn't look exactly like that. Use a standard flare tool, set it up for a double flair and stop befor the first step is finished.
    There's a tool they sell that rides the inside of the pipe and makes a outie ridge but it ****s
    warbird1 likes this.
  3. tb33anda3rd
    tb33anda3rd
    i have actually done something like that by sticking a philips screw driver in the end and twisting. once the tip is in wiggle it around a little.
  4. J. A. Miller
    J. A. Miller
    from Central NY
  5. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Google tube beading tool.
  6. Yep ! ^^^
    That's the one that ****s
  7. V8 Bob
    V8 Bob
    Correct. What you end up with is a metric "bubble" flare that works very well with hose.
  8. Rusty O'Toole
    Rusty O'Toole
    Use the flaring tool and bulge the end just a little. You don't need to bear down all the way.
  9. 1-SHOT
    1-SHOT
    from Denton
    There are hydronic flaring kits that make the posh lock connecters and they are close.
    I think Eastwood sells one, I got mine from the Snap -On tool man.
  10. 32 hudson
    32 hudson
    I have used a farrel type union connection before. Place the nut and farrel on the line. Tighten nut to union, loosen and then hack saw off the nut. Leaving the farrel as a stop so the hose with a clamp will not pull off .
    56premiere and Rich B. like this.
  11. $400.00.
    Then the jiffy ***e dies are an add on
    LOU WELLS likes this.
  12. blue 49
    blue 49
    from Iowa
    A friend of mine (airplane enthusiast) has a tool set that has different sized mandrels that go into the tube and you roll the tool around like a tubing cutter, increasing pressure a little at a time, to raise the bead. I made myself a die that slips over the tube, with a chamfer to match the chamfer on my flaring tool. I leave about 1/16" clearance between the two parts and squeeze it with the flaring tool. Works pretty good.
    Gary
  13. ago
    ago
    from pgh. pa.
    How about some photos?
  14. blue 49
    blue 49
    from Iowa
    10.JPG 20.JPG 30.JPG 40.JPG 50.JPG Here is the tube end of the die with a 3/8, flat bottomed hole and the chamfer. Next is the other side of the die with a 90*countersink for the flaring tool. Next is set up to use. Next is compressing the tube. Last is the finished tube end. This is aluminum fuel line because I didn't have a s**** of steel. The steel actually comes out a little better because the clamp doesn't crush the tube as much.
    Gary
  15. stimpy
    stimpy
    mastercool is the MFG of the tool its cheaper to buy it from a supply house .
  16. stimpy
    stimpy
  17. blue 49
    blue 49
    from Iowa
    Here is another tool I've made for large tube for splicing radiator hoses. It's just simple dies welded to a pair of locking pliers. I just lay out a line and go around the tube a couple of times, moving about an 1/8" at a time. The s**** of tube I used here is 16 ga exhaust tubing.
    Gary
      152.2 KB
      160.2 KB
      141.3 KB
    tb33anda3rd likes this.
  18. nmpontiac
    nmpontiac
    from Taos, NM
    I've got an old Kent-Moore AN flaring tool set that goes from 3/16 to 5/8 and it has a beading die for each size. I love these old tools. AN flare tool.jpg
  19. ago
    ago
    from pgh. pa.
    This a great idea, along with the post by blue49. Thanks for posting.
