Hello all, I bought a 53 Chevy 150 some months ago and have just started to work on it. I bought a 235 w/powerglide and stock rear end from a fellow Hamber, and have since installed it. I also have a new wiring harness (not installed yet). I want to run new brake lines and new MC also. I guess I kinda want to know what I should do first. I seems like everytime I go work on it, I feel overwhelmed. I know I should start and finish one thing at a time, so thats why I'm asking if theres a certain order I should follow. Keep in mind that money is a bit tight, so it is a budget build. I just wanna get it on the road, the body and paint can wait. Any help is greatly appreciated. Thanks in advance.
Since you have it running, I'd do the wiring harness next, that way you can check everything with the battery hooked up and/or the car running...make sure it all works. Then, since it's running and wired correctly, you can move on to the brakes. If it goes forward and backward, it needs to stop. R-
